'73-'77 rear lower control arms
Old Jul 18, 2009 | 12:56 PM
doc's Avatar
doc
I read in an old Car Craft story that you can use the '73-'77 a-body rear lower control arms in the '64-'72 a-body's (same length, etc). I know the sway bar mounts on the bottom, etc., but is this true?
I have a '74 442 that I'm partting/scrapping & may use the rear sway bar & LCA on my '66 F-85.
Thanks!
D
Old Jul 18, 2009 | 02:03 PM
Thanks!
D
I don't know about interchangeability, but I do know that the sway bar on the 73-77 cars mounts to a U-shaped piece of sheet metal that fits up inside the LCA and bolts in place using the holes that would normally be used for the 64-72 sway bar. I never thought that was a very good design structurally, since the boxing plate on the earlier LCAs turns the open section arm into a MUCH stiffer box. Frankly, I'd just weld a plate to the bottom of you old arms, with nuts welded to the inside if you want to mount the 74 sway bar.
Old Jul 18, 2009 | 03:26 PM
doc's Avatar
doc
Just curious mainly....just seeing what I could use off of the 442 before scrapping it.
Thanks for the info!!
D
crazy'boutOlds
Oct 4, 2011 05:45 PM
66-3X2 442
Oct 4, 2011 09:13 AM
RAMBOW
Mar 16, 2011 03:56 PM
1970442w30post
Drivetrain/Differentials
Jan 11, 2011 06:07 AM
JSGD1966
Oct 5, 2010 08:26 PM
