72 Supreme Convertible Coil spring replacement
Old Oct 26, 2025 | 07:00 PM
flameorange's Avatar
Hi folks found a broken front spring, 72 Supreme Convertible, 350 no AC.
1. Can I just replace front springs, use original rears?
2. do convertibles use different springs than hardtop?
Newbie, thanks for your help!
Drivers broken spring, been that way for about 30 years 😆
Old Oct 26, 2025 | 07:28 PM
If the rear is not sagging you can use the original rears. I don't think there is a difference in front springs unless you go to a BBO.
Old Oct 26, 2025 | 07:31 PM
Use Rears
thats what I was planning, use orig rears, have to figure out a reasonable front replacement…
thanks!
67cutlassguy
Mar 22, 2019 02:39 PM
Rvsmith5
Jul 24, 2018 10:26 AM
pg1
Mar 2, 2015 02:18 PM
wisniows
Nov 25, 2014 05:53 AM
442iowa
Suspension & Handling
Feb 13, 2012 05:05 PM
