71 B Body Pitman Arms
Old Jan 27, 2010 | 09:57 PM
Gustav455's Avatar
hey guys, im replacing all the suspension in my car. Ive got everything except the pitman arm. I cant seem to find one anywhere, parts stores just show not availible. Not on ebay either. 1971 Oldsmobile Delta 88,
thanks Gustav
Old Jan 28, 2010 | 12:08 AM
copper128's Avatar
Lt. Buzzkill (ret.)
I'm curious: Why do you need to replace the pitman arm?
They're not usually available aftermarket because they don't wear out. Unless it was damaged somehow or you're changing from power to manual steering, it shouldn't need replacement.
Old Jan 28, 2010 | 04:08 PM
Gustav455's Avatar
i was just wanting to put all new suspension under it because most of the parts were rusted, i got everything replaced except the pitman arm, i cleaned it up, its not too bad, i was just going to replace it since i was under the car, the steering wheel does have some play in it still though although i replaced everything i guess since i cant get one i will just put it on the alignment rack tomorrow and get that done, i can fix the play then and then its to paint and seats redone, thanks for the info though
mdfedewa
Suspension & Handling
Mar 28, 2013 05:38 PM
cut123
Mar 28, 2013 08:54 AM
scrappie
Feb 13, 2010 04:41 PM
Brodyvonsickboy
Oct 15, 2009 10:59 AM
J-(Chicago)
May 29, 2008 04:30 PM
