69 Cutlass S center link rubbing
Old Jun 6, 2022 | 08:34 AM
lala5818's Avatar
The center link on my 69 Oldsmobile cutlass S convertible is rubbing the tip of the frame. All my front steering and suspension is new. Any ideas why it’s rubbing?
Old Jun 6, 2022 | 10:00 AM
4speed455's Avatar
Looks like you have it assembled incorrectly. The grease fittings on the tie rods should be facing the frame.
Old Jun 6, 2022 | 10:08 AM
The drag link is also installed backwards and as stated the tie rods are on the wrong side of it.
Old Jun 6, 2022 | 11:33 AM
lala5818's Avatar
thank you!!
Old Jun 6, 2022 | 02:59 PM
Loaded68W34's Avatar
Those are also the outer tie rods. The inners have grease fittings on the cast part and face toward eachother. Once installed, the ones you currently have attached to the center link will have the grease fitting facing the ground.
H70 Olds
Dec 8, 2021 05:52 PM
STLCRZY
Suspension & Handling
Feb 4, 2019 11:32 AM
archeryshooter
Feb 25, 2013 08:12 AM
1962oldsguy
Apr 6, 2012 08:36 PM
mmurphy77
Feb 20, 2011 09:47 PM
