67 442 front spring length
Old Jul 9, 2025 | 07:19 PM
Bigdibbs88's Avatar
Hi All-
I have my front suspension out and am wondering about my front springs. The car is a low mileage example which sat for many years… since at least the early 1990s. Would you recommend replacing the springs or not necessarily? I’m also wondering what the uncompressed length should be… mine both measure about 15-3/4”. No AC automatic car if that’s relevant
thank you!
Old Jul 9, 2025 | 07:49 PM
Well dang, I have the Moog spring application data on a USB hard drive, but since I’m on an Apple device and Apple made a conscious decision to NOT allow connection to USB storage media, I am not able to post the spring information. I’ll try later after I dust off my Windows machine.
Old Jul 10, 2025 | 04:58 AM
Originally Posted by Bigdibbs88
Hi All-
thank you!
Keep in mind that free height of a spring isn't the only thing that determines ride height. Spring rate matters as well. You can have two springs with different spring rates and correspondingly different free heights and the ride height will be the same. The spring with the lower rate will be softer and need to have a taller free height, but once loaded they will be the same.
Old Jul 10, 2025 | 05:54 AM
Supernice88's Avatar
Art S
They sell an adapter. https://www.apple.com/shop/product/M...04286a777e02b4
Old Jul 10, 2025 | 07:12 AM
Hairy Olds's Avatar
Shoveling Snow
How many miles on the car?
Old Jul 10, 2025 | 12:56 PM
I don't have anything with USB-C. Plus I absolutely hate doing anything with picture uploading on portable Apple devices.
Old Jul 10, 2025 | 01:02 PM
I looked at the spring data and it does not have any applications for a 442 with 400 cid engine, only Cutlass with 330 engine.
Old Jul 10, 2025 | 02:40 PM
Art S
I give up...
Old Jul 10, 2025 | 02:43 PM
Bigdibbs88's Avatar
about 25,000 miles. My concern is more around them being compressed for 60 years, but I don’t know enough to know which factor is bigger. Just wondered if anyone knew if that was about the right uncompressed length before I spend time blasting and repainting the originals
Old Jul 10, 2025 | 03:36 PM
Hairy Olds's Avatar
Shoveling Snow
I replaced my springs at about 30,000 miles because I thought the same thing.
Replaced with a service replacement set and it rode at the same height so no gain there.
It seems the mileage means more to the to ride height than anything else.
Try and find a good set of Eaton springs if you want to compare.
Old Jul 11, 2025 | 06:58 AM
Run to Rund's Avatar
That free length is about right for the 425 lb/in 442 front springs.
Old Jul 11, 2025 | 05:41 PM
Bigdibbs88's Avatar
Thanks all, I will blast and paint the originals
oldsrush
Suspension & Handling
Jun 9, 2023 08:46 PM
Richard Miller
Sep 19, 2021 02:34 PM
Kid Thunder
May 11, 2015 10:46 PM
67BB
Mar 1, 2013 06:49 AM
charlierogers
Dec 21, 2011 07:14 PM
