1971 Rear coils springs
Old Mar 19, 2021 | 10:47 PM
riskyb's Avatar
Can someone tell if a 1971 Cutlass has Variable Rate Spring or Constant Rate Spring stock from the factory? Thanks
Old Mar 20, 2021 | 05:46 AM
Variable rate springs have the coils spaced closer at one end of the spring and constant they will be evenly spaced.
Old Mar 20, 2021 | 08:39 AM
riskyb's Avatar
Good info but what was stock in 1971?
Old Mar 21, 2021 | 05:43 AM
oldoldss's Avatar
The coils on mine are evenly spaced, so I'd say constant rate.
Old Mar 21, 2021 | 06:08 AM
oldoldss's Avatar
Page 4-90 of the assembly manual shows the rear spring options. The standard rear springs on a Cutlass (3287 or 3269) were 106 lb/in. For F41 or FE2 suspension, the rates were higher.
67cutlassguy
Mar 22, 2019 02:39 PM
wyocutlass
Suspension & Handling
Aug 14, 2016 06:11 PM
1971gutlass
Mar 18, 2014 07:36 AM
72hurst
Feb 2, 2011 06:32 PM
iuhoops83
Mar 17, 2008 05:54 AM
