1964 F85 Cutlass Lower Ball Joint
Old May 19, 2024 | 03:52 AM
64f85convertible's Avatar
Hello - New to Oldsmobile. Doing a drum to disc swap 64 f85 cutlass convertible. I have the drum assembly off and are left with the BJ in control arm. Struggling to get the lower removed. Were these welded on the 64’. Do I have to buy a new control arm with BJ already installed? Thanks
Old May 19, 2024 | 04:39 AM
Sugar Bear's Avatar
Not welded in from the factory but they may have been tacked afterward if replaced and the hole was enlarged. Should be able to see any tacking from the bottom where the joint meets the arm.
Old May 19, 2024 | 05:19 AM
Thanks. Guess I just need a little bit more muscle and a bigger breaker bar.
Old May 19, 2024 | 06:05 AM
Not sure what a breaker bar will do for you. These ball joints are pressed in. You either need the correct ball joint "C-clamp" tool or you need to remove the arm from the car and use a hydraulic press. Actually, truth be told, in my young and impoverished days I got the ball joint out with a sledge hammer, supporting the underside with a length of pipe. Today I have a 20 ton press.
Old May 19, 2024 | 08:21 AM
Sugar Bear's Avatar
Penetrating oil, not WD 40 generously applied top and bottom to the interference fit area can't hurt. Put some pressure on the clamp and strike the clamp screw downward, re tighten a little, strike it with reasonable force don't wail on it re-tighten and repeat.
Old May 19, 2024 | 08:40 AM
Got it off!! Tighten, wack, tighten, wack. Appreciate the input. Top has the rivets. Seems it great shape so might be keeping that one as is.
Old May 19, 2024 | 08:53 AM
Sugar Bear's Avatar
If the original is excellent I'd leave it, the uppers usually last far longer than the lowers. Old school quality vs. new replacement? I'll take the original again, if they are excellent.
Guillaume
Apr 12, 2022 03:36 AM
deaddds
Aug 1, 2020 09:36 AM
John1963
May 14, 2013 04:05 AM
Stattiolds69
Suspension & Handling
Mar 22, 2011 06:51 PM
red61
Dec 2, 2008 08:29 PM
