distributor hold down
Old Nov 27, 2015 | 10:54 AM
serta1's Avatar
I have a question about timing. I adjusted the Dwell to 30 using the allen wrench. Now I am trying to do the timing, supposed to be 8. I see that 8 is the second bump from the top end of the timing tab. But I am not able to figure out where to loosen the distributor to turn it. Is there some hidden bolt somewhere? Also I cannot see the timing mark on the belt pulley. I presume that is where the mark is? Thank you for your help.
Old Nov 27, 2015 | 10:59 AM
I moved your post to its own thread instead of resurrecting an old one. The distributor hold down clamp bolt is at the bottom of the distributor. Just loosen it a bit until you can turn the distributor.
Old Nov 27, 2015 | 11:04 AM
redoldsman's Avatar
Proud Viet Nam Veteran
There is a clamp on the drivers side of the distributor that has a bolt through it with a 9/16 head. Loosen the bolt just a little and you will be able to turn the distributor. You will probably need a distributor wrench to loosen and tighten it. You can get a cheap one at Harbor Freight that will work just fine. You don't say what car you are working on but the timing marks are probably on the harmonic balancer. When you find them you may want to mark them with some white paint.
Old Nov 27, 2015 | 11:05 AM
lemoldsnut's Avatar
You did not say what your car and engine is? If you provide that maybe someone can provide a picture to show you?
Old Nov 27, 2015 | 12:05 PM
I will ***-U-ME you have a 1964-1990 Olds V8. If not, ignore the following. The photo shows the rear of an Olds block. The large hole in the center of the picture, above the bellhousing surface is where the distributor goes. The small hole to the left of this is where the bolt that holds the distributor clamp threads into.
Old Nov 28, 2015 | 03:50 PM
jaunty75's Avatar
I always waited until the third date, but a complete answer is under #1 here where timing is specifically discussed.
http://www.match.com/magazine/articl...The-New-Rules/
Old Nov 28, 2015 | 04:22 PM
Octania's Avatar
that's funny jaunty
I find that a 12" extension and 9/16 flex socket make a good combo for doing the distributor clamp bolt.
Old Nov 28, 2015 | 08:39 PM
If you've got a 12" extension, then it's definitely wise to wait until the third date to roll that bad boy out...
I agree that it's wise to wait until the third date in general, but, I must admit, if I have a chance on the first date, I'll take it - there may not be another.
Oh, it's possible that his distributor is frozen in place, and a previous owner discovered this when trying to tune it up, and didn't bother to reinstall the clamp.
If that is the case, the distributor must be moved by force (and penetrating oil), and then a new clamp must be obtained.
FIRST 442
Jul 1, 2018 06:59 AM
shinewill
Sep 17, 2011 05:25 AM
78cutlass
Jul 17, 2009 04:43 AM
mcutlass1969
Mar 9, 2009 08:54 PM
Pfiffle
Sep 22, 2008 05:10 PM
