lifter tap $$ ?
Old September 21st, 2015, 11:01 AM
VikingBlue's Avatar
lifter tap $$ ?
might buy 72 supreme 350 ci. wondering what I might expect the repair to cost and might there be unknown longer term engine damage revealed by the lifter tap ?
VikingBlue is offline
Old September 21st, 2015, 11:25 AM
Since Olds engines have non adjustable rockers, lifter noise is a common occurrence for hi mile engines. You may need to replace rockers and perches, lifters, and worst case possibly a cam. The only way to find out the condition is to pull the intake and inspect everything.
Another issue may be low oil pressure and that can be related to bearing clearances which ultimately will lead to a complete rebuild.
oldcutlass is offline
63super88
September 17th, 2014 10:19 AM
442craig
February 21st, 2014 04:15 AM
1971viking
July 13th, 2012 10:05 AM
Railguy
April 9th, 2012 07:29 AM
olds70supreme
July 24th, 2011 08:27 AM
Quick Reply: lifter tap $$ ?
