55 Olds 324 dual point gap
Old Feb 25, 2015 | 12:52 PM
scharpp's Avatar
Scharpp
Hi all, anyone know what the gap and timing is on a 324 with dual point distributor, Thanks
Old Feb 25, 2015 | 02:06 PM
Is it a Mallory?
Old Feb 25, 2015 | 02:54 PM
scharpp's Avatar
Scharpp
Didn't look like one, I will have a closer look tonight, im a body man not a mechanic lol
Old Feb 25, 2015 | 02:57 PM
Nope, now your a mechanic also. If it's a Mallory there is usually a plate or a stamp on the side that tells the specs for setting.
Old Feb 28, 2015 | 07:20 AM
scharpp's Avatar
Scharpp
it is a delco
Old Feb 28, 2015 | 09:29 PM
Ozzie's Avatar
Post
The original distributor required a 0.016" breaker point gap (cam angle of 26-33 degrees), but it was a single point distributor. It sounds like someone did a modification to a dual points beaker plate. Look on the breaker plate itself. It may show the required gap.
Old Mar 1, 2015 | 07:44 AM
Try .022 gap with a single point dwell of 26 and combined dwell of 33.
Old Mar 4, 2015 | 06:37 AM
edzolz's Avatar
When I was running a dual point dist. I would block the secondary set of points with a piece of popsicle stick and set the gap on the primary points. Run the engine and see if it missfires. Then block the primary set and set the gap on the secondary set. The engine will run on only one set of points while the other is being set. Then check the dwell. It should be on spec.
Old Mar 4, 2015 | 01:09 PM
scharpp's Avatar
Scharpp
Thanks all I will give it a shot
442dreamer
Jan 20, 2018 07:52 AM
2blu442
May 11, 2014 05:38 AM
442stang
Cars Wanted
May 27, 2012 06:56 PM
Mattia-SS
Mar 23, 2012 12:30 PM
