Hooker 3901HKR headers
Old Feb 23, 2014 | 12:43 PM
Eric Anderson's Avatar
Just a quick note to anyone wondering about these headers. The fit is very good no clearance issues on my 1970 with a 350. In the instructions it says the car must be at least 3' in the air to install the passenger side, if you remove the trans cooler lines it will go just having it up on jack stands. On the drivers side there is a heat shield on the motor mount, if you change your mount leave it off, they won't clear it. The rear bolts on the drivers side are very tight, I reccomend starting the rearmost bolt then slipping the flange over it, then put one in the front, leave them both a little loose, then put the second from the rear in. After that you are golden.
Old Feb 25, 2014 | 05:04 PM
mccrosky2004's Avatar
Thanks for the tips Eric. I'm going to be installing these headers this weekend.
Old Feb 25, 2014 | 07:12 PM
When I was cleaning everything up today I noticed the instruction sheet that I had was for the big block headers. I looked up the correct instructions today and it doesn't mention the 3' clearance for the small block just a FYI. It also doesn't mention the need to disconnect the trans lines but I just could not get the header past mine, maybe they were replaced with some oddly bent lines or something. Once I disconnected them from the trans the header slipped in with no issue. Good luck with your install.
JSGD1966
Jan 14, 2009 08:39 PM
JSGD1966
Nov 12, 2008 06:36 AM
JSGD1966
Oct 14, 2008 10:25 AM
JSGD1966
Aug 27, 2008 07:46 PM
spikey0922
Jan 11, 2003 11:31 PM
