Qjet Secondary Shaft Spring Tension
Old Apr 3, 2013 | 10:18 AM
442dreamer's Avatar
Hello all, a carb rebuild noob here. I'm doing my first major qjet rebuild and have run into a problem. After installing shaft bushings on the primary and secondary shafts, I have reattached the throttle body to the main fuel bowl.
I can't find a way to tighten the spring around the secondary shaft on the side of the throttle linkage. The two books I have been using, Doug Roe's and Cliff Ruggles' great books, do not seem to say how to do this, or at least I can't find it anywhere. Have I missed a step when putting it all back together? Basically, how do I tighten this spring?
This first picture is where the spring is right now, the second is where it needs to be, and the third was a picture I took before disassembly, showing the spring tightened.
Old Apr 3, 2013 | 10:58 AM
jarrod's Avatar
Looks like the straight tail on the spring goes to the base plate. Look close in pic 3.
Old Apr 3, 2013 | 11:53 AM
442dreamer's Avatar
Yep that did it! Guess I just needed another pair of eyes on it for a change, thanks a bunch!
oldspackrat
Sep 13, 2020 05:23 PM
Johnny Cage
Aug 9, 2012 08:56 PM
AZ455
Aug 30, 2011 03:09 PM
bulldog
Aug 17, 2011 08:25 AM
Gunfreak25
Mar 15, 2011 11:05 PM
