307 timing chain cover
Old Feb 25, 2013 | 03:07 PM
Jhughes0's Avatar
The water pump attaches to a flat metal plate that covers the timing chain. Is there a gasket under the plate that seals engine oil ?
Old Feb 25, 2013 | 03:14 PM
Yes
Old Feb 25, 2013 | 03:25 PM
henryk8398's Avatar
Hangin' out...
This is the gasket set for my 1983 Ninety-Eight.
Amazon Amazon
The gasket on the right with the two holes is the one you need. I don't know if those are available individually, but the kit is cheap so grab one. That way, you'll have an extra water pump gasket. You get two in the kit. One is for A/C and the other is for NON-A/C equipped cars. Also included in that is are the fuel pump gasket, front crank seal, and front oil-pan seal. Fel-pro should make the same kit. Should be easy to find at a parts store.
at3reg98
Jul 30, 2013 04:01 PM
83lesabre
Jul 3, 2012 10:46 AM
dallasite21
Jun 20, 2010 05:37 AM
crazy'boutOlds
Aug 6, 2009 05:40 AM
sklbndt
Apr 15, 2009 04:34 PM
