oil pressure sender size???
Old Apr 22, 2012 | 08:06 PM
805cut's Avatar
Will a Universal Pressure Sender with a 1/8" NPT fit my 1970 350?!
and what size water temp sender would i get ?
need to order both online and want them to show up and fit!!
thanks guys
Old Apr 23, 2012 | 06:43 AM
Yup. That's the thread size in the block.
Old Apr 23, 2012 | 08:13 AM
805cut's Avatar
thank you.
Old Apr 23, 2012 | 08:18 AM
AZ455's Avatar
1974 DELTA 88
I believe water temp on my 455 is 1/2" NPT. Don't know if 350 is the same?
Old Apr 23, 2012 | 08:59 AM
Yeah, they're all the same, Bryan.
Old Apr 23, 2012 | 09:43 AM
Not sure how that relates to a question about the oil press sender...
Old Apr 23, 2012 | 10:28 AM
'Cause he asked about both, Joe:
Gotta get your money back from that speed-reading class .
Old Apr 23, 2012 | 11:05 AM
Redog's Avatar
An electrical oil sending unit of 1/8 NPT will fit thread wise, but the unit itself will not fit between the timing cover and intake manifold. You'll need an extension pipe of some kind. I had an extra part left over from a gauge pod I bought
Old Apr 23, 2012 | 12:01 PM
DOH! Sorry, I completely missed that.
[/QUOTE]Gotta get your money back from that speed-reading class .
- Eric[/QUOTE]
That brings to mind the old Cheech and Chong routine about the Evelyn Woodhead Sped Reding Course...
Old Apr 23, 2012 | 12:10 PM
"I ricommend these Evelyn Woodhed Speed Riddin Course to all my frens out there..."
Old Apr 23, 2012 | 12:32 PM
805cut's Avatar
aye yi yi
already a piece of pipe there... which brings me to another question for you guys..
Today i installed a oil pressure gauge so i can keep an eye on my oil pressure till my digital gauges are up and running.. When I fist hooked it up i started the car (cold) and the psi was around 45. Which was a big deal beacause this meant that the oil pressure is fine and the reason my digital gauge showed such a low reading was perhaps result of the sender on its way out or bad wiring. But after about 10 miles of normal operation the gauge went back down to 0 but when i would get on the gas it would rise some but only to like 25. At warm idle it was 0!
I pulled over and poped the hood thinking the oil pressure line for the gauge was leaking causing a drop in pressure, but when I poped the hood with the motor running I noticed there was about a inch long pocket of air in the tube right next to where the oil comes out of the motor..
Dose this mean my motors not pushing oil? I just got the car and have no honest clue as to when the oil was changed last could dirty oil have clogged it? any suggestions would be great lol this thing is killing me!
Old Apr 23, 2012 | 12:39 PM
Nasty455's Avatar
XCELERATIONRULES!
Go to our Interactive Catalog for more cool features Filter By Keyword(s): Find More Parts Related Parts (Contains 0 Items) View Advice Choose for Me to Minimize Cost
1970 : OLDSMOBILE : CUTLASS : 5.7L 350 cubic inch V8 : Electrical-Switch & Relay : Oil Pressure Switch PriceAdd to Cart STANDARD MOTOR PRODUCTS Part # PS12T More Info T-Series
WITH LIGHT
$3.28
AIRTEX / WELLS Part # 1S6649 More Info {#10045707, 1119214, 1266085, 1508286, 1508319, 1508425, 1508753, 19021012, 1998149, 1S6820, 3751700, 3815936, 3818783, 389966, 3973617, 549099, 5653196, 5653197, 6460391, 6462550, 6462849, PS24}
W/Light, Exc. Rally Pack- Stocked in outlying warehouse--shipping delayed up to 1 business day
$4.01
STANDARD MOTOR PRODUCTS Part # PS12 More Info {#10045707, 1508286, 1508425, 1508753, 19021012, 1998149, 2815936, 3615936, 3751700, 3815936, 3852215, 38522157, 3915936, 3973617, 557458, 5653197, 6460242, 6460391, 6462550, D1837, G1803, G1807, SW333, SWG1355, SWG333, U1801A}
WITH LIGHT
$6.66
ACDELCO Part # D8050 More Info {#89057533}
SWITCH,ENG OIL PRESS IND 1/8IN X 27 DRYSEAL THRD
$7.23
STANDARD MOTOR PRODUCTS Part # PS12X More Info
WITH LIGHT (Only 2 Remaining)
$9.85
Old Apr 23, 2012 | 12:42 PM
Nasty455's Avatar
XCELERATIONRULES!
If the motor was not pushing oil...you'd know about it quickly.
Oil gauges are always a pain...if you do run one,make sure you use the correct copper tubing and not plastic.
Old Apr 23, 2012 | 12:43 PM
... after about 10 miles of normal operation the gauge went back down to 0 but when i would get on the gas it would rise some but only to like 25. At warm idle it was 0!
Stop. Do not pass GO. Do not drive that car until you figure out what is wrong.
Operating with no oil pressure will destroy your engine, if it hasn't already.
... there was about a inch long pocket of air in the tube right next to where the oil comes out of the motor..
This is normal. There was air in the tube to start with when you connected it.
Yes. You have zero oil pressure, therefore it is not pushing oil until proven otherwise.
Old Apr 23, 2012 | 01:37 PM
805cut's Avatar
Im going to bleed the oil line.. See if that makes a diffrence i know air bubbles are normal but this is ALOT of air... And lets say my car isent moving oil, how would i explain the gauge working when i first hooked it up ?!
Only things i can come up with is air in the line or some sort of little debrie stuck somewhere.
Cause at low rpm there is no reading but at higher rpm the gauge gose up to about 25, I would say this cars been driving without any reguard to oil pressure for atleast 6 months by the previous owner, if there was really ZERO oil pressure im sure the thing would be toasted by now
Old Apr 23, 2012 | 02:49 PM
Nasty455's Avatar
XCELERATIONRULES!
You don't want a ton of oil pressure anyhow..you just want a steady reading.
Lot's of people go through the trouble of restricting oil to the rockers to give the bottom end more protection and cooling.
The oil needs to flow to the parts,but blasting past the parts at high pressure does nothing extra special.
Old Apr 23, 2012 | 04:08 PM
EVERYBODY take a deep breath!
If the air pockets we're talking about are in the translucent plastic oil line to a mechanical gauge, that's ALWAYS the case. This is nothing to worry about. The air remains trapped. You don't need to bleed it. Just live with it.
BeenThere
Dec 29, 2016 02:04 AM
StickW31
Jan 7, 2013 08:51 AM
Dec 6, 2011 03:58 PM
christine fury
Apr 8, 2010 09:27 AM
olds_man
Oct 8, 2009 08:59 PM
