Heat Riser Valve 371
Old Mar 2, 2012 | 03:31 AM
caddy60's Avatar
Hello!
I´ve just been wondering, if 371 needs the heat riser valve?
Is it worth installing? There was not that valve, when I bought the Olds.
My Olds is such new for me, and I don´t really well know,
how should 371 work. The choke tube may be good
to replace?
My car is 1957 4D Super 88 with J-2
I´m just so novice..
Best regards,
Juho
Old Mar 2, 2012 | 07:27 AM
D. Yaros's Avatar
I take it the valve is not working. Is it stuck open or closed? Open is fine. Closed is not good
Unless you drive the car in cold weather, the heat rise valve is not needed. Its purpose is to divert exhaust gas to the intake manifold to warm the fuel.
However, if you remove it, you do have to occupy the space with something to avoid an exhaust leak. If you want to retain the housing, simply remove the butterfly valve.
Old Mar 2, 2012 | 07:38 AM
You can take a piece of bailing wire and tie it open, or take it to a muffler shop and have them weld it open. Either way will work. It does not effect the operation of the motor other than it helps it heat up faster.
Old Mar 2, 2012 | 09:00 AM
Tedd Thompson's Avatar
Heat riser
Guy's, he is from Finland, cold starts could be a problem. A new heat riser valve is available from Fusicks new, part #HRV 490. I think they ship over seas....Tedd
Old Mar 4, 2012 | 03:21 AM
belgium57olds's Avatar
hello juho ,
I removed mine , no problems with cold starts even in the winter .
regards
marc
Old Mar 4, 2012 | 08:47 AM
Destructor's Avatar
My older early 70's cars never had them. I used them in zero degree weather with no problem. My 88 caprice had one. I would say if the rest of your hot air warm up system for the air cleaner is working you should be fine.
Old Mar 4, 2012 | 10:27 AM
caddy60's Avatar
Hello, everyone!
Thank You for Your answers!
Yes I´m from Finland, but I don´t drive my Olds during the cold season.
I won´t put that valve back..
This is so nice forum!
Thanks!
Juho
1977 Delta 88 Flint
Dec 24, 2012 11:25 PM
matchek
Aug 19, 2012 08:48 PM
viper771
Oct 29, 2011 12:42 AM
ROCKET VAPOR
Oct 20, 2011 11:35 AM
bjtstarfire
Nov 13, 2008 02:04 PM
