Is this set-up OK w pics
Old Aug 26, 2011 | 04:26 AM
RetroRanger's Avatar
72 Olds CS
72 OLDS 350
For my PCV I have my drivers side valve cover w a PCV valve that goes to the PCV port on my edlebrock I think thats normal. For the pass side valve cover the vent goes to the under side of my air cleaner I think it used to go to the outside of the air cleaner with a filter on the end. I dont have the original air cleaner set-up I didn t get it w the car
So is it OK that the pass side potentially sees some vacuum when originally I dont think it was really under vacuum at all ??
thanks in advance
Old Aug 26, 2011 | 04:51 AM
CQR's Avatar
CQR
That looks fine. The passenger side will be able to pull clean fresh air into the crankcase if the pcv valve pulls more than the blowby creates.
Old Aug 26, 2011 | 05:10 AM
Lady72nRob71's Avatar
You are right. The carb is sucking engine fumes through the PCV valve (nothing but a check valve) and fresh air will be entering the other side through the round filter (which is not a very good filter if you drive in dusty, dirty areas.)
Old Aug 26, 2011 | 06:55 AM
Thats basically whats been on my car for the past few years and it works great for me!!!
cutlassgal
Aug 30, 2011 07:08 AM
cutlassgal
Aug 29, 2011 03:02 PM
cutlassgal
Aug 29, 2010 05:51 PM
cutlassgal
Aug 26, 2010 09:10 AM
