Rebuilding 350 rocket '68
Old Aug 11, 2011 | 12:22 PM
swesson's Avatar
Hi all, I've stripped down my 350 rocket out of my 68 cutlass and I have a couple of questions-
How can I tell if the valve seats have been replaced so the engine will run well on unleaded?
I could do with a set of big end ( connecting rod) bearings the numbers that are stamped into my set are-
GMMA 68299 & 283AT
Can anyone tell me what size they are?
That will do for now I'll think of some more soon.
Old Aug 11, 2011 | 12:46 PM
swesson's Avatar
And... What do the numbers on the heads mean? Mine are no.5
Old Aug 11, 2011 | 01:06 PM
svnt442's Avatar
The heads are correct for 68-69 350's. The bearing numbers don't mean anything to me, but I'd guess they are original.
Old Aug 11, 2011 | 09:32 PM
64Rocket's Avatar
For me, hard seats are for people that drive there old cars 50,000 miles a year.
If you only drive 5,000 a year, then it is not that important.
So if you took the heads off and there was steel shim head gaskets, then your heads are bone stock, no hard seats. If you are worried about unleaded fuel get some #7A head from a '72 350 Olds, that have factory harden seats.
As far as bearings go, you will have to go after market bearings. The machine shop will measure and determine from there as to what size to use.
same with the pistons, as to bore or not to bore.
Gene
Old Aug 12, 2011 | 12:20 AM
swesson's Avatar
some pics.....
Old Aug 12, 2011 | 01:46 AM
svnt442's Avatar
WTF? Was it face down in the mud?
Old Aug 12, 2011 | 04:06 AM
That's the way engines in the rest of the country look.
We have this thing called rain, which causes this thing called rust.
Old Aug 12, 2011 | 04:32 AM
69442C's Avatar
It sure looks that way given all the mud that is packed into that crank pulley.
Old Aug 12, 2011 | 07:00 AM
Rain??? Whats that, we here in N Texas have forgotten what that looks like!!
Old Aug 12, 2011 | 08:11 AM
64Rocket's Avatar
There seams to be normal amount of dirt in the crank pulley. There is a plate in the pulley with two bolts to hold it in, just for that reason to keep a huge amount of dirt off the pulley. If you look close you can see the bolts. My '68 also has that.
Gene
Old Aug 12, 2011 | 08:48 AM
You'll know when it comes -
The temperature will drop below 105!
Old Aug 12, 2011 | 11:22 AM
svnt442's Avatar
Gene
Wow I've never seen one of those before. It looked like the pulley was PACKED with mud.
Old Aug 13, 2011 | 11:46 AM
swesson's Avatar
Is this better?
Old Aug 15, 2011 | 02:09 PM
64Rocket's Avatar
You know if you use a rubber mallet and tap back a fourth, and pull up at the same time . that oil filler tube will come out. Use a rubber mallet and smack the tube pretty hard and pull up. It will come.
Gene
zeppigio
Jul 11, 2014 09:37 PM
motor
Oct 2, 2013 04:27 PM
LangfordBoy
May 30, 2009 05:04 AM
77omega
May 13, 2008 06:54 PM
staying-old80
Sep 11, 2007 01:23 PM
