oil leak from carb
Old Jan 14, 2011 | 01:35 PM
fitter bill's Avatar
oil leak from carb
hello my 72 cutlass s with 350 -4 all edelbrock leaks oil from carb base gasket onto manifold . now i have installed new pcv valve & breather and my valve covers have built in baffles in them . the engine runs fine no smoke plugs are good i have also tried new gasket between carb & manifold & still get a leak any help BILL
Old Jan 14, 2011 | 01:52 PM
oldsguybry's Avatar
NOVICE car nut
ok , that explains why I get puddles of oily substance on my intake manifold , was wondering wth that was from
Old Jan 19, 2011 | 07:15 AM
jpc647's Avatar
I have a very similar problem too. I have no idea. But now I know where it comes from too.
Old Jan 19, 2011 | 07:52 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Is your air cleaner getting oil in it?
If the breather/pcv system is new and correctly hooked up, I'd guess worn piston rings, or your oil drain back holes in the low side of the heads are clogged, and the oil is only able to come down the push rod holes and puddling.
Old Jan 19, 2011 | 08:48 AM
If that were really oil leaking from the carb, your car would be blowing so much oil smoke out the exhaust that you wouldn't be able to see the carb. More likely you are seeing fuel that is collecting grease from the engine compartment and looking like oil.
Old Jan 19, 2011 | 02:54 PM
thanks for the responce guys Joe the car has 111500 miles on it i lifted off the carb & found oil around base gasket but not alot down the throat of intake .i do have blowby but not sure if its to much or normal for the amount miles that are on the car. thanks BILL
Old Jan 19, 2011 | 03:45 PM
body 51's Avatar
does your engine have oil consumption issues? if not i would agree with joe
Old Jan 19, 2011 | 04:14 PM
no not at all except for the little puddle in one of the valleys of the manifold BILL
Railguy
Tech Editor's Desk
Jul 25, 2010 02:36 PM
Grumpy
Aug 22, 2008 08:29 PM
Holiday55
Jun 5, 2008 03:49 PM
cutlassdriver61
Feb 6, 2007 05:52 PM
