power steering belt
Old Apr 19, 2007 | 02:56 AM
ztim's Avatar
power steering belt
How can I get the unit loose so I can get the belt back on? I just changed the water pump on the 1984 Delta 88 (thanks Oldsguy) and have everything tight except that belt. There is a bolt behind the pulley, got that one loose, and there is one behind the power steering pump but it is almost impossible to get to unless the alt ? bracket is removed and I don't even know if that is the right one. Thanks
Old Apr 19, 2007 | 08:49 AM
ozoneblue's Avatar
Are there any holes in the pulley? if so the bolts are behind them
Old Apr 19, 2007 | 09:05 AM
ztim's Avatar
Yes, like I said, there is one behind the pulley. I got that one.
Old Apr 19, 2007 | 02:31 PM
There are two bolts behind the pulley and a nut on a stud on the backside. You need to loosen all three to get the pump to move. When tensioning the belt, you need to use a pry bar or large screwdriver between the nose of the pump (behind the pulley) and a tab that's located on the bracket. This lets you get the belt good and tight without damaging the sheet metal reservoir on the pump.
Old Apr 19, 2007 | 03:05 PM
ztim's Avatar
I finally got it. I was not putting enough pressure on the large screw driver I was using as a pry bar. It is all back together now. Next time I change water pump it shouldn't take so long! Thanks for the help everyone!
bob
marzgtp1
Jan 16, 2022 06:19 AM
455cutlass1969
Aug 5, 2014 08:06 AM
EightyEightCut
Aug 29, 2012 12:13 PM
cluelesscutlass
Jan 3, 2012 06:18 AM
Olds98
Aug 6, 2010 05:02 AM
