oil restrictors
Old May 19, 2010 | 08:57 AM
dman0712's Avatar
oil restrictors
im using the mondello oil restrictors in the 3 main saddles of my 403. I did not however use locktight before i installed them. I also elongated the main bearing holes. DO i really need to worry about them falling out? The engine is already together.
Old May 19, 2010 | 10:43 AM
Where do you think they're going to go? The absolute worst thing that could happen is that they slide down to the backside of the main bearing shells. So what? They can't fall out.
The only danger is to your wallet for buying "restrictors" that don't really restrict anything...
Old May 19, 2010 | 10:48 AM
dman0712's Avatar
Yes but i drilled out the main bearing holes so couldnt it possibly fall out?
Old May 19, 2010 | 10:59 AM
dman0712's Avatar
i looked at the holes and they are drilled out enough where if the restrictor did fall out it would not be stopped by the bearing shell.
Old May 19, 2010 | 03:00 PM
oldsonharmont's Avatar
"The only danger is to your wallet for buying "restrictors" that don't really restrict anything..."
Joe, I take it you don't think the restrictors are a worth while expense... please explain?
Old May 19, 2010 | 03:28 PM
dman0712's Avatar
Can someone please answer the original question?
Old May 19, 2010 | 03:55 PM
citcapp's Avatar
Sre the threaded or driven in? What does Mondello have to say about this issue
Old May 19, 2010 | 11:43 PM
88 coupe's Avatar
Junior Member
........ Do I really need to worry about them falling out? ........
Oil pressure will hold them in place.
........ The absolute worst thing that could happen is that they slide down to the backside of the main bearing shells ........
Resulting in a restriction at his oversize hole in the bearing?
Originally Posted by citcapp
........ What does Mondello have to say about this issue
From the Mondello Technical Manual, Volume 1
Originally Posted by Joe Mondello
Main bearing oil holes should be enlarged to 17/64". Oil restrictors should be installed in the main bearing housing holes. Also, the fitting at the front of the block that squirts oil on the timing chain should be plugged.
Originally Posted by oldsonharmont
........ I take it you don't think the restrictors are a worth while expense ........
He, and a lot of others.
https://classicoldsmobile.com/forums...tml#post171389
Norm
Old May 20, 2010 | 12:58 PM
cutlassefi's Avatar
The oil is limited by the small hole in the restictor anyway
Norm
If you didn't put one in the first hole then I wouldn't sweat it too much. if that one slips down then it will block the passage to the driver side lifter oil galley I believe. Then you have a problem.
Old May 21, 2010 | 07:15 PM
dman0712's Avatar
If i do decide to take them out can i do so by lifting of the crank? the pistons are already installed
Old May 21, 2010 | 10:38 PM
88 coupe's Avatar
Junior Member
To answer your question: You would have to remove the crank and bearings, in order to to gain access to the restrictors. If you used a hammer to install them, you will need a hammer to remove them.
To give you some advice: If you used a hammer to install them, they will not fall out.
Norm
Old May 26, 2010 | 10:58 AM
dman0712's Avatar
do i just use a punch to push the restrictors down and out the cam bearing hole toward the top of the block or what? WIll my oversized holes in the main bearings be ok without the restrictors or should i get new bearings? I thought the restrictors help to keep more oil on the crank
Old May 26, 2010 | 03:27 PM
Warhead's Avatar
Fresh, pressurized oil comes from the passenger side lifter galley, through an angled-drilled hole in the block to the main bearing saddle, on the back side of the bearing.
Make sure the restrictor does not block other angled holes at the juncture.
The restrictor is only to hold back oil going straight up to the cam bearing.
I like the hole at the main bearing to be larger than the hole to the cam.
Many main bearings now available, do not match the oiling hole correctly in the block saddle.
This mis-match causes an oiling issue (restriction) at the main bearing. NOT GOOD.
Opening the main bearing hole only does good things for the crankshaft.
If you have already opened them up, leave them that way.
My opinion
Jim
Old May 26, 2010 | 03:36 PM
dman0712's Avatar
my choice is either remove restrictors or install new main bearings. How do i go about removing the restrictors?
Old May 26, 2010 | 05:00 PM
dman0712's Avatar
ok because thats what i did. I opened up the hole enough so the entire cam hole was exposed but if i keep it that way i would like to remove the oil restrictor because if for some reason it does slide out the bearing shell will not stop it.
Old Jan 12, 2026 | 06:44 AM
BBLima's Avatar
From my understanding with Joe Mondello restrictors process was not just putting restrictors in 2,3,4 mains is 1/2 of the job. For the bearings to benefit from the restrictors, the lower bearing shells Journals 2, 3 and 4 should be opened up with 5/16 drill, then elongated, toward the center of oil hole restrictor with regular round rat-tail file. End of groove must line up with center of restrictor hole.The Bearing will now receive full benefit of extra oil remaining downstairs, thanks to the restrictor plugs. This is according to The master of Oldsmobile engines. Joe Mondello himself.
Old Jan 12, 2026 | 08:18 AM
And yet, a review of the oiling diagram shows that all the restrictors do is reduce oil to the cam bearings.
Old Jan 12, 2026 | 09:08 AM
BBLima's Avatar
I am a believer, shifting at 8500 rpm with a bb olds with no problem on bearing wear. Would of it been the same without??? Ill never know.
Old Jan 12, 2026 | 04:06 PM
cutlassefi's Avatar
dman0712
Jun 2, 2010 02:07 AM
86pontiac
Feb 17, 2010 11:24 AM
442 Guatemala
Mar 28, 2009 01:58 PM
geckonz08
Sep 4, 2008 04:10 PM
neoinbiz
Nov 6, 2006 12:11 PM
