intake nr. and automatic question
Old May 15, 2010 | 11:18 AM
D Appeldorn's Avatar
can't vind my intake nr at the tech side anymore.
it's 390327, lost my paper note
and il have a th 400 hydramatic behind my 350.
Il checked the numbres and it say's that my nr bolts on the 350.
but i thought a th400 is a th400 and should also work on a 455?
where's the difference? or weakness
Old May 15, 2010 | 12:06 PM
De TH 400 kwam met de 400 ci en de 455 ci. De 350 kwam met de 350 motor. Veel mensen gebruiken de Th 350 met de 455. Het is niet zo sterk, maar het werkt goed
Doei Doei
Old May 16, 2010 | 03:15 AM
compaired my numbers next to my 69' chassismanual.
And it say's it's a th400. on the tag. ( as extra option)
also read that there was a difference between the th400 behind a 350 or 455.
difference i don't know, but my tag say's this th400 should bolt on to a 350 engine.
I noted several numbers of parts, so it is easier to order stuff.
why a th400 i don't know got everything, brake asist, disk's at front, huge 6blade fan, th400, type o axel with RA housing,
and a micy 350???
should expect a 455 why bother a th400 and diskbrake's on front
But it brake's as the devil hit a few times the front screen
Old May 16, 2010 | 03:17 AM
this th400 has a tag plate bolted pasengerside, th350 should recon at round dent plate?
so it's in the manual
svnt442
Jul 17, 2011 04:43 PM
Giddy
Jul 31, 2010 04:41 AM
DennisG.
Oct 29, 2008 10:31 AM
denis
Feb 22, 2007 11:51 PM
