Need help with identifying my Olds Rocket V8:
I'm looking for some help here. I have an Olds Rocket v8 motor with a Hydramatic transmission. I was told from the guy I bought the car from that it was a 324 CI. But the issue is that I have a Olds factory Tri-Power (with rochester carbs) sitting on top, which would make it a 371 ci. The following cast numbers are:
Number on the rear of Block on Bell Housing - 568929
Number on the Intake - 571145
Number on Block just in front of left rear cylinder - A377506
I was told that the factory Tri-Power will not fit on a 324 ci.
I want to use this motor, but do not want to put money into it if someone force fit the intake on the heads/block.
Can anyone out there positively Identify this motor for me with the information I have provided?
Thank you.
Thank you.
