Timing chain olds 403
Old Jun 22, 2021 | 02:32 PM
jarco's Avatar
Hello,
This timing chain seems too loose to me.
But the chains and sprockets don't seem to be really worn yet.
What's smart to do?
I hope you have some good advice.
Jarco
Old Jun 22, 2021 | 03:48 PM
rocketraider's Avatar
Oldsdruid
How many miles on engine?
Can't get a good look but appears the cam gear is all steel which means it's been replaced.
Since you're already that deep into it, replace it on general principle. Timing sets are cheap enough.
Old Jun 22, 2021 | 04:26 PM
That's a double roller chain. It shouldn't be that loose. Has this block been line-bored?
Old Jun 22, 2021 | 06:03 PM
cutlassefi's Avatar
That’s the problem, it’s most likely a cheap replacement.
Old Jun 22, 2021 | 06:16 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Cloyes Street roller perhaps? How many miles? The Cloyes SR had slack out of the box, glad Cloyes discontinued that set.
Old Jun 22, 2021 | 06:46 PM
HighwayStar 442's Avatar
Cloyes Gear Timing Chain and Gear Sets in mine no problems! You should check the center to center measurement. Cloyes sells a reduced center distance set if needed.
Last edited by HighwayStar 442; Jun 22, 2021 at 07:37 PM. Reason: Reduced center distance set
Old Jun 22, 2021 | 10:15 PM
jarco's Avatar
I don't know how long it's been there.
Old Jun 22, 2021 | 10:23 PM
jarco's Avatar
It would have been recently overhauled. If it's line-bored is i ​have no idea
Old Jun 22, 2021 | 10:26 PM
jarco's Avatar
Hi, what would be the center to center distance?
Old Jun 23, 2021 | 03:15 AM
https://www.cloyes.com/part-finder/?...=applicationhp
Center Distance = 5.044
0.005" Reduced Center Distance Set for Align Honed/Bored Blocks Center Distance = 5.039
Engine builder on here know better than me. I am just a engine assembler who done a few.
Old Jun 23, 2021 | 04:42 AM
BillK's Avatar
Boy that is looooose That does not look like a Cloyes part number to me. More likely a cheap knockoff. I have been using Cloyes timing sets for over 30 years and have never had an issue with them.
Can you find out the history of the engine ? You really need to measure center to center but that is very difficult if not impossible to do on an assembled engine. Do you have anyone close by that might have a stock timing set you can try first before you order a new one ? Where are you located ?
If your problem is caused by the chain being stretched and you order a set for the shorter center to center then it will probably be too tight. You might just need a new timing set to fix the issue.
Old Jun 23, 2021 | 05:26 AM
jarco's Avatar
Thanks for the reply.
I'm going to measure the center to center size and I order one new timing set.
Old Jun 23, 2021 | 06:46 AM
The Cloyes Street roller had that sloppy issue, the other ones seem fine. Another member got one with the same issues as mine. He went with the Cloyes Billet 9 way set Mark recommends and uses in the build. It was way tighter out of the box. Seriously, mine looked like that after just a few thousand miles. If the motor was a recent rebuild, he may need the reduced distance set. I may also need that set, it depends on how much is removed with an align hone.
Old Jun 23, 2021 | 02:06 PM
jarco's Avatar
Thanks for the good help!
Tomorrow I will replace the distribution.
It's a double chain. Does anyone have a good tip for set it on the time?
Old Jun 23, 2021 | 03:19 PM
cutlassefi's Avatar
Cloyes has that number. That’s how they gauge their sets.
A timing chain lesson- most of your inexpensive 3 keyway sets come from one or two manufacturers. They may say “Made in USA” on the crank sprocket and most think the whole set is made here. WRONG! All that means is that gear is made here. Typically the chain is from overseas and the cam sprocket can be from anywhere.
if you want a truly matched set then use the Cloyes 9-3613x9. From there they offer sets for line bored applications. Anyone want to guess how those sets compensate for a shorter centerline distance?
Hope this helps.
Mark
Old Jun 23, 2021 | 03:22 PM
Hope this helps.
Mark
Larger crank gear??
Old Jun 23, 2021 | 04:42 PM
Hope this helps.
Mark
Isn't that a German chain option for the Cloyes Billet roller sets? Is the dash 5 the undersize? Do I need the undersize with an align honed block? My guess would gear size as well for the undersize.
Old Jun 24, 2021 | 12:37 AM
jarco's Avatar
Does anyone have a clear explanation of how to set it on time? It's also my first time with a GM engine.
Old Jun 24, 2021 | 03:52 AM
cutlassefi's Avatar
Larger crank gear??
You're half right.
Old Jun 24, 2021 | 08:08 AM
BillK's Avatar
Take the metal splash shield off the crankshaft and then take a picture from the front showing both sprockets and the chain. If the distributor is still in the engine do not remove it or turn it in any way.
Old Jun 24, 2021 | 01:57 PM
jarco's Avatar
Installed the new set today. Went pretty easily without any special tools. Here is the result.
Thank you for all your tips.
Old Jun 24, 2021 | 02:08 PM
Sugar Bear's Avatar
Can you attribute the difference to anything specific e.g., gear vs. chain vs. some of both?
​​​​​​Glad to see it works, good luck!!!
Old Jun 24, 2021 | 02:13 PM
jarco's Avatar
[QUOTE=Sugar Bear;1351218]Can you attribute the difference to anything specific e.g., gear vs. chain vs. some of both?
​​​​​​Glad to see it works, good luck!!![/QUOTE
when we removed it I measured the distance between sprocket and sprocket with chain on it. The difference was about 2 millimeters.
Old Jun 24, 2021 | 02:21 PM
That's better! Did you find your leak?
Old Jun 24, 2021 | 02:25 PM
jarco's Avatar
Yes there was a kind of bump in the bottom seal. He was probably not properly put it in and that's why it leaked.
Old Jun 24, 2021 | 03:10 PM
That looks so much better. What timing set did you use?
Old Jun 24, 2021 | 10:08 PM
jarco's Avatar
I have a edelbrock 7813 used. It wash the one with the fastest delivery. Otherwise it would the next week.
Old Jun 25, 2021 | 05:27 AM
A good idea, that should have been mentioned is your cam should have been degreed. It takes some work and is easiest with the heads off. At the very least, a degree wheel should check the accuracy of the timing set. Sadly some are way off. The 3 sets I checked were accurate. Unfortunately the accuracy of the Edelbrock sets is one of them, look at the reviews of that timing set. Hopefully you got a good one and at least it won't skip a gear.
drjr56
Apr 19, 2020 07:27 AM
NewcuttyBuddy7
Sep 16, 2015 08:28 PM
nonhog
Feb 18, 2012 07:02 PM
olds87
May 24, 2006 08:30 PM
lunatic
Jan 14, 2005 12:02 PM
