Lifters Collapsed
Old Jul 26, 2020 | 12:56 PM
user 7408240824's Avatar
Lifters Collapsed
Have a '68 rocket 350, 5.7 with '74 7-A heads. I race my car, over 3 years it has sat a lot and the engine has run for probably only 3-4 hours in that time because I don't get to race often. It has always been strong but just this week I checked my valve train and all rockers were loose. We made adjustments and retightened but it seems the lifters are collapsing because you are able to push the pushrod down into the cam with almost no effort. Is this due to how much the engine has sat? The lifters would pump back up with oil after we ran it and gave it some oil pressure, but then would go soft again. They are not staying, and some of the rockers are bottoming out on the threaded bolt when we tighten them. The cam and lifter set I have is a performance comp cams model # CL510991-08. Any ideas/comments are helpful.
Thank you,
Steven
Old Jul 26, 2020 | 01:09 PM
I would not run that engine after adjusting the lifters the way you did. You need to google the EOIC method for adjusting valves and readjust yours. If your out of adjustment at the rockers you will cause harm to your engine if you mange to even get it started.
Old Jul 29, 2020 | 08:41 PM
Lifters Collapsed
Hello,
Have a 68-70 oldsmobile rocket 350 with '74 7A heads. Hydraulic flat tappet lifters are collapsing. I've had these lifters for about 3 years, raced with them a few times. Probably only 3-4 hours of engine running time in those 3 years, it say mostly. Engine was rebuilt when they were put in and always taken good care of. The lifters have gone soft and caused a tapping. If I press the pushrod in and out i can manually pump them back up with oil and they become solid, but after a few cranks of the engine they go soft again. My engine has good oil pressure. I disassembled and the lifters, cam lobes and pushrods are in excellent condition. Only thing damaged is bottom of rocker arms as they are bottoming out on the studs when tightening. What is the reason for this?
Specs:
Crane cams aluminum roller rockers - 80-1.60, -11
Trick flow pushrods 8.500 .080
Howards cam performance hydraulic lifters 91411
Howards cam hydraulic flat tappet camshaft CL510991-08
Thank you,
Steven
Old Jul 29, 2020 | 09:47 PM
OLDSter Ralph's Avatar
Do you have guide plates for the push rods ? Do you have the correct rocker arm studs ?
Old Jul 30, 2020 | 10:12 AM
There is no need to start multiple threads for the same issue, it just confuses things.
Old Feb 23, 2021 | 07:45 PM
66SportCoupe's Avatar
You haven't told us what rocker setup you're running. If it's adjustable or not.
Old Feb 23, 2021 | 07:47 PM
Ok my bad. It seems you have roller rockers and full adjustment. When lifters bleed down there may be some slop however with a roller rocker and hydraulic cam it should not move much
cdrod
Jun 9, 2021 03:07 PM
user 7408240824
Jul 26, 2020 01:09 PM
Oldsaussie
Aug 13, 2017 04:54 PM
Pryora
Aug 6, 2012 11:30 AM
1971 442 convert
Apr 13, 2011 04:32 PM
