1970 350
Old Feb 18, 2020 | 04:54 PM
Oldscutlass123!'s Avatar
1970 350
Hello everyone I’m in need of help I have a 1970 350 block non ac with 6 heads I would like to build this engine up but I don’t know where to start or what to buy my goal for horsepower is 400. I’d be building the engine in stages buying parts from time to time I jus need help putting a parts list together and what needs to be down to the block and heads
Old Feb 18, 2020 | 05:07 PM
cutlassefi's Avatar
I did a project 350 a couple of years ago. It dynoed at 417hp amd 430tq. I used the following parts;
Mahle 4.100 350 piston and ring kit
#7a heads with 2.00/1.62 valves, with bowl blend, multiangle valve job, crossovers filled, center divider welded up.
Erson TQ40 cam, 220/228@.050 on a 108lsa
Brawler 750 Vacuum secondary carb
Performer RPM intake with center divider cut.
Flowtech 1 3/4 headers
Hope this helps.
Old Feb 18, 2020 | 05:54 PM
Did you use a stock crank
Old Feb 18, 2020 | 05:59 PM
cutlassefi's Avatar
Yes a Nodular one, internally balanced.
Oldscutlass123!
Feb 12, 2020 09:37 PM
68442
Apr 28, 2016 03:43 PM
Shradezz70S
Jun 13, 2014 06:34 PM
507OLDS
Jan 21, 2014 11:15 AM
jims2000lt
Jul 21, 2013 01:42 PM
