Performer RPM intake
Old December 26th, 2018, 03:25 PM
cruisin72's Avatar
Anybody use an Edelbrock performer RPM for a 350 in a 72 Cutlass or similar A body? Debating over which intake to go with. I'd like to use the RPM but am concerned about hood clearance.
cruisin72 is offline
Old December 26th, 2018, 04:37 PM
Clearance should not be an issue. The bigger issue is it a match to your engine? The operating band is 1500-6500 rpm, for a stock engine its a bit overkill.
oldcutlass is online now
Old December 26th, 2018, 06:26 PM
Agreed. There’s no clearance issue (I have one on my 350) and the question of whether it’s a match for your engine setup is key. For a stock engine it’s overkill and likely detrimental to performance.
Fun71 is online now
Old December 26th, 2018, 07:16 PM
cruisin72's Avatar
Nothing real radical. 4.080 bore 350, 9.7-1 compression, 218/226 @ .050 hydraulic roller cam, very mild stall.
What do you think, RPM too big?
Old December 26th, 2018, 08:34 PM
Chevy budget Olds powered
coppercutlass's Avatar
The Rpm will be fine. Even in a stock app. Should clear and not be an issue. I wouldn't bother with a performer. For your set up it will be perfect.
coppercutlass is online now
Old December 27th, 2018, 07:27 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
There is an argument on the Performer vs RPM. Some have shown on a 9 to 1 350 a gain with the Performer at the track. Others have claimed gains on vin 9 307's with the RPM at the track. With your motor, which isn't very mild, a RPM will work very well. I could probably put a 1" spacer on my RPM and it would still fit on my 70. I lost performance going from a Performer with a 1" open spacer to a RPM intake. I would bet 99% of the loss was going from a 2300 to 1600 flash stall and weaker first gear of the TH350 vs the TH2004R. What gearing do you have? What is a mild stall?
olds 307 and 403 is offline
Old December 27th, 2018, 09:01 AM
cruisin72's Avatar
This car will have a 3.73 rearend gear and the TH200R4 transmission, with an 1800 RPM convertor as stated by the transmission builder.. And I forgot to mention, it will also get a sniper EFI setup.
Old December 27th, 2018, 09:05 AM
cruisin72's Avatar
You guys that have run the RPM with a square bore holley, did you just use the thin adapter plate from edelbrock? Any sealing issues?
Old December 27th, 2018, 09:26 AM
I ran a 1 inch open no issues.
Old December 27th, 2018, 10:09 AM
Upgrade that converter to something like a 2200 to 2500 stall. You have enough cam and compression to warrant it. I went from a 2300 flash stall, rated at 2200 to 2500 rpm. I currently have a stock stall that flashes at 1600 rpm, it sucks with my 9 to 1 350 with a 214/214 cam. I went from 1/4 block burn outs to barely spinning the tires. Hopefully your builder upped the shift points from factory 4000 rpm to 5000/5500 rpm full throttle shift points.
Old December 27th, 2018, 10:20 AM
X2 for the bigger stall. Even with a mild cam you may have a hard time setting the idle rpm in gear due to ir being tight. A stock stall was tuneable with my carb but when i went to tje sniper EFI on my Pontiac it did not like a big rpm drop and it would die. I could have tuned for it with the efi but i suspected tje converter being tight for a long time. Just fwiw. I ran a 2800 stall and it was good on the street in my cutlass went to a 3500 stall. Not horrible but most may not like its characteristics .
Old December 27th, 2018, 12:35 PM
He also has lock up which means less slippage, another bonus. Higher stall along with lock up is the best of both worlds.
Old December 27th, 2018, 03:14 PM
cutlassefi's Avatar
Just an FYI, when these companies give an rpm range, it’s for the entire engine family given. In other words, apples to apples this intake would rpm higher on a 307 than it would on a 403. Again apples to apples.
cutlassefi is offline
Old December 27th, 2018, 04:31 PM
I didnt want to go there but i ran an rpm intake on a 307 with a 650 DP Holley. On a stock 307 lol. Was a peppy little engine in my 72 when i was between 350's. Would lay rubber like it was no ones business.
Gone Johnson
February 12th, 2018 07:39 PM
69ishHoliday
August 18th, 2013 06:31 PM
jpc647
April 30th, 2013 01:47 PM
Mark30
August 13th, 2012 02:15 PM
mp71conv
November 1st, 2008 05:10 AM
Quick Reply: Performer RPM intake
