radiator question
Old October 27th, 2017, 06:00 AM
denf221's Avatar
radiator question
I have a 72 supreme, stock 350, is it a 3 or 4 core? Think I need to replace it what should I go with?
denf221 is offline
Old October 27th, 2017, 06:41 AM
Dave26's Avatar
Just replaced the radiator in my 72 supreme. I picked up mine at Summit. I am using their Classic OEM radiator. Fits perfectly in the saddles, trans lines....etc.
Dave26 is online now
2blu442's Avatar
What part of the country do you live in? If in the Northern states or Canada the 3 row might be fine. If the Southern states where its hotter in the summer you might want the 4 row. The simplest would be replace whatever you already have. If you presently have a 2 or 3 row and upgrade to the 4 row you'll have to change the brackets at the bottom of the radiator, and get a different top plate. So I'd consider your climate and goals for the car. I tend to overbuild just for the extra margin of safety, but that's just me!
2blu442 is offline
Old October 27th, 2017, 06:43 AM
2blu442's Avatar
If your not sure what you have right now, look inside the radiator and count how many rows of tubes thick the core is. It could be a 2, 3 or 4 row.
2blu442 is offline
Old October 27th, 2017, 09:03 AM
Without A/C, it's a two row. With A/C, it's a three row. I can almost certainly guarantee that you don't have a four row. The core support and top plate for four row radiators are different. Is there any reason why simply replacing with an original style (or better, just having the original recored) is not an option?
joe_padavano is offline
Ranmat
October 9th, 2019 05:11 PM
Alex72cutty
June 4th, 2017 03:15 PM
Alex72cutty
April 21st, 2015 10:30 AM
59Olds98
August 14th, 2013 09:38 AM
g77rvd
May 13th, 2011 11:29 AM
Quick Reply: radiator question
