Idle Up Solenoid
Old Apr 30, 2017 | 06:56 PM
77ricbaez's Avatar
Idle Up Solenoid
How do I adjust the idle up solenoid? I tried to adjust it engine running, ac on, compressor wire disconnected and the stupid screw doesn't turn at all. Is it busted or what?
Old Apr 30, 2017 | 08:20 PM
Happy Trails's Avatar
I have the 1977 service manual, and this is what it has on that topic:
That might not provide any more information than you already know, but I'm not seeing much else as far as information on how to make that adjustment.
Old May 1, 2017 | 10:36 AM
oddball's Avatar
There were a couple of different solenoids - just in case yours got swapped or replaced.
Some are adjusted by turning the rod that comes out of the solenoid. If this is frozen, then you need to get it unfrozen (BFH?) or find a better functioning one.
Some have extra threads on the body of the solenoid and are adjusted by moving the entire solenoid closer or further from the throttle. The retaining nut has a lock plate to hold it in place.
You could have a locked up solenoid, or the wrong type.
73rocketship
Jul 6, 2012 06:45 AM
67442HT
Jul 14, 2011 04:35 PM
roomer
Jul 11, 2011 06:36 AM
68conv455
Sep 21, 2009 10:48 AM
Chumley
Apr 11, 2008 07:08 PM
