timing for a w-31 350 motor
Old Mar 7, 2009 | 07:46 PM
matt442olds's Avatar
hi to all i had put a w-31 olds 350 motor in a 85 442 i would like to know if any one my know the timing for this motor. thank you for any help.
Old Mar 7, 2009 | 08:23 PM
88 coupe's Avatar
Junior Member
Welcome to the site.
14° BTDC at 1100 RPM.
Norm
Old Mar 8, 2009 | 03:57 AM
Bobsw32's Avatar
BobsW32
Do you still have the motor?
Old Mar 9, 2009 | 09:00 AM
Thank you for the info.
Yes I do have the motor. The motor is in my 85 442. The car was setting in the garage for 12 years I had blow the bottom bearings. I was looking for a olds motor and everyone was telling me to get a chevy 350 crate motor. After looking around I found a 76 olds thinking it was a 403 motor, I still picked it up for $700.00. After removing the motor and trans. My friend seen the valve cover saying W-31 so I checked the #'s on the motor and found that it is a 350 W-31 motor. I opened the motor up and it was clean and the same for the TH400 trans. I put a new Edelbrock 600cfm, new drivestaft and exhaust system dual with flowmasters. As soon as I can figure out how I can post pic I will do so. Thank you
Old Mar 9, 2009 | 10:50 AM
olds68's Avatar
If you truly have a W-31 motor, you have a piece of gold. Check for the thick vibration dampener. Those are tough to replace and are a tell tale sign of the W-31. The motor will rev to 7000 unlike a stock 350.
Let us know what you find.
Old Mar 9, 2009 | 11:46 AM
Realy, I would never of know that an olds motor would rev to 7000. The #'s on the block 395558 2 on the heads 403 859 6 on the back of the motor by the distributer the #'s read CFD 174 13 does this mean anything.
Old Mar 9, 2009 | 11:47 AM
I love the 68 that you have.
Old Mar 9, 2009 | 12:00 PM
olds68's Avatar
No, the numbers don't mean anything to me. And I can't readily check mine since the car is cocooned for the winter. Check that harmonic balancer of yours and see how thick it is. Plus the motor will not want to idle well under 800 rpm and the vacuum will be under 10 lbs. at idle.
But get it over 3000 RPM and it wants more
Oh, and THANKS for the complement
Old Mar 9, 2009 | 12:30 PM
Okay, I will check tonight and you are right about the idle thats why I asked about the timing if I was doing something wrong. Let me ask you this do you think that the 600cfm carb okay?
Old Mar 9, 2009 | 12:40 PM
olds68's Avatar
600 CFM should be fine. I ran a 650 Holley spread bore and performance was virtually the same between that and the stock Rochester.
Old Mar 9, 2009 | 08:59 PM
88 coupe's Avatar
Junior Member
Originally Posted by olds68
........ Plus the motor will not want to idle well under 800 rpm
Idle speed should be set at 625 RPM, in Drive, with the AC off.
Norm
Old Mar 10, 2009 | 06:32 AM
thank you, i will try to do it this weeken.
Old Mar 10, 2009 | 08:15 AM
olds68 question the balancer seams to be thicker but what is the normal thickness on a reg. 350 so i can compare the two?
Old Mar 10, 2009 | 09:24 AM
olds68's Avatar
Here's a picture of the W-31 balancer. I believe that the stock issue is 1-1/4 or 1-1/2 " thick.
Old Mar 10, 2009 | 09:55 AM
thank you so much. your the best
Old Mar 11, 2009 | 12:51 PM
olds68
I had check last night it was hard to measure do to the pully was on but what i can see and measure it is about 2" wide.
kelly bakies
Nov 19, 2014 05:30 PM
72cuttys
Jun 28, 2014 11:03 AM
jpc647
Jun 10, 2013 11:48 AM
QS442
Nov 30, 2011 05:45 PM
442scotty
May 13, 2009 05:42 PM
