Two Barrel/Four Barrel Intake
Old Jan 23, 2017 | 08:46 AM
VI Cutty's Avatar
Is the stock intake manifold for a 1971/2 350 the same for two and four barrel carbs, or different manifolds for the application?
Going to be swapping a 350 with a two barrel into my new '70 and will be rebuilding a QJet for it later this year.
Old Jan 23, 2017 | 08:51 AM
classicmuscle442's Avatar
The intake are the same, only difference is between small and big block Olds because of deck height.
Old Jan 23, 2017 | 09:01 AM
VI Cutty's Avatar
That makes life easier, thanks!
Old Jan 23, 2017 | 09:38 AM
Um, what do you think?
Old Jan 23, 2017 | 09:47 AM
oldsmobiledave's Avatar
what?
What does deck height have to do with carburation? He asked if 2 & 4bbl are the same not if SBO & BBO are the same. I don't understand your answer.
Old Jan 23, 2017 | 09:54 AM
In fairness, given the obvious answer to the original question, I think his eyes saw one thing and his brain read something else. I'd be lying if I said I'd never done that.
Old Jan 23, 2017 | 10:30 AM
VI Cutty's Avatar
A picture's worth a thousand words; thanks for the clarity, Joe.
Old Jan 23, 2017 | 12:56 PM
woops, meant block deck height difference from small and big block not carb opening. On pain pills from shoulder surgery. nap time
Old Jan 23, 2017 | 03:48 PM
76olds's Avatar
Hookers under Hood
Its ok, our members understand mistakes happen, especially when pain takes over the mind.
We have great members here that post corrections without bashing the poster that makes the error.
Cheers, have a good nap,
Eric
Old Jan 24, 2017 | 03:20 PM
BlackGold's Avatar
I see your point, Joe. The 2 bbl manifold has the thermostat housing on the right, while the 4-bbl has it on the left. Clear as day.
Old Jan 25, 2017 | 05:59 AM
I'm glad SOMEBODY'S paying attention.
Old Jan 25, 2017 | 12:28 PM
VI Cutty's Avatar
Well I'm screwed then. Both my intakes have the housing on the right.
AND I misplaced my left handed screwdriver.
Old Jan 25, 2017 | 12:44 PM
Thought I had one I could lend you, but I checked, and it's metric.
Old Jan 25, 2017 | 07:36 PM
Metric
That's fine. We use the metric system here in Canada.
Beau Dirt
Dec 27, 2021 03:02 PM
RetroRanger
Nov 21, 2016 10:11 AM
edzolz
Oct 10, 2014 08:55 PM
442much
Oct 30, 2010 08:48 PM
