Any issues running the Camaro repro dual snorkel on an Olds 350?
Old Dec 17, 2016 | 05:52 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Plan on buying on and running it on a Performer intake with a 1" spacer using a Qjet carb. I will add the round silver Oldsmobile Rocket 350 decal, either the 8" or 11", depending on which fits better.
https://m.summitracing.com/parts/amd-w-460a
Old Dec 17, 2016 | 05:55 AM
I don't see any issue as long as you have clearance.
Old Dec 17, 2016 | 06:13 AM
That is really my only issue, not a points restoration. I figure it will filter better with decent air flow and look more stock than an open filter.
Old Dec 17, 2016 | 04:16 PM
You can run dual ram air hoses also
Old Dec 17, 2016 | 04:21 PM
wr1970's Avatar
There is a specter kit that is cheaper.
Old Dec 18, 2016 | 06:24 AM
Thanks, going that route, as they come with hoses to make them a true ram air, different sizes and angles. A much better option, just have to decide on which one.
Old Dec 20, 2016 | 07:22 AM
jpc647's Avatar
Make sure you post photo's when it's done!
Old Dec 21, 2016 | 05:01 AM
I will do. Here is the air cleaner set up I am planning on. As long as there is enough space.
https://m.summitracing.com/parts/spe-7118
Along with this decal on top.
http://srx.ca.ebayrtm.com/clk?RtmClk...712&pi=2050601
Old Dec 21, 2016 | 05:47 AM
x2
costpenn
Sep 20, 2014 06:21 AM
2blu442
Nov 11, 2013 06:10 AM
BeenThere
Oct 5, 2013 01:31 PM
Nilsson
Apr 18, 2010 04:12 PM
SJenkinzz
Jan 14, 2009 06:04 PM
