Sanderson headers question
Old Oct 16, 2016 | 03:52 PM
Sporty45's Avatar
What's the difference between Sanderson street rod 455 headers and 350 headers? Other than primary diameters? These are the ones I'm referring to:
Old Oct 16, 2016 | 04:52 PM
redoldsman's Avatar
Proud Viet Nam Veteran
These are hot rod headers with the outlet in the center. The 350 headers exit in the rear where they clear steering in A body cars.
http://www.sandersonheaders.com/var/.../O351_600.jpeg
Old Oct 16, 2016 | 04:57 PM
Sporty45's Avatar
Yes, I am aware that they are hot rod headers, but sanderson makes a 350 version of them that look identical to the 455 ones. I'm just trying to figure out the difference between the 2. Here is the 350 version:
Old Oct 16, 2016 | 05:44 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Tube size is one, the 455 headers have 1 7/8" primary with 3" collectors . I had a set of the 1 5/8" primary with 3" collector center dump 350 headers in ceramic. They have all the dimensions on their website. According to their site, the 350 headers are 2.5" from flange to the edge of the tubes and 7.5" from the top of flange to the bottom of the collector. The 455 headers are twice as wide at 5" and one inch longer at 8.5".
Old Oct 16, 2016 | 06:01 PM
Sporty45's Avatar
Thanks, I suspect they will work just fine for my project then.
Old Oct 16, 2016 | 06:04 PM
What are your project plans? Those 350 headers hug nearly as close as manifolds.
Old Oct 17, 2016 | 02:48 AM
Sporty45's Avatar
They are going on a 350 in my 47 coupe. Getting a brand new ceramic coated set off ebay for $165 less than list price. If they don't work out, I'll put em up here in the classifieds. Just too good of a price to pass up!
Old Oct 17, 2016 | 06:37 AM
Probably the same place I bought mine. They were a super price and nice, much cheaper than anywhere else. I bought them for the Olds powered 4x4, worked but due to being a 4x4, exhaust routing was too tight on the driver's side. I then bought uncoated O351 rear dumps. As long as you are using front mounts and have clearance under the center of the motor, they should work. I would use Copper or aluminum collector gaskets, regular ones don't last. RTV works great, just like Sanderson suggests between the exhaust ports and header flange.
Old Oct 17, 2016 | 09:47 AM
Sporty45's Avatar
Yup, front mounts with plenty of clearance under the motor. The front clip is out of a 93 vette. Thanks for the tip on collector gaskets.
70cutty
Dec 8, 2016 10:47 AM
Kyle's 77 Cutlass
Apr 13, 2014 11:30 AM
Delmont 88 PA
Feb 3, 2013 06:11 AM
olds 307 and 403
Jan 24, 2012 03:28 PM
|-K|=K
Jul 28, 2011 03:02 PM
