Another crankcase ventilation ?
Old Aug 25, 2016 | 09:17 PM
76olds's Avatar
Hookers under Hood
I took my original oil cap off a few years ago. I put a push in type Edelbrock Breather type of part in its place. Its vented, is this OK or should I be putting the original oil cap on the oil fill tube? Will it hurt anything leaving the push in breather in its place?
Eric
Old Aug 25, 2016 | 09:25 PM
coppercutlass's Avatar
Chevy budget Olds powered
I ran one in the fill tube for years no issues. I did this because i didnt want to knock out the holes in the M/T valve covers.
Old Aug 25, 2016 | 09:32 PM
76olds's Avatar
Hookers under Hood
Thanks Copper!! I wipe some oil residue off around the bottom of it each time I decide to clean the other chrome engine parts. Good to hear it isn't an issue so I'll leave it on.
Cheers
Eric
Old Aug 26, 2016 | 06:10 AM
Do you have a PCV in one VC and a breather in the other. If so then you can put the cap back on your filler tube.
Old Aug 26, 2016 | 07:08 AM
76olds's Avatar
Hookers under Hood
I have both PCV and Breather. PCV on one cover and breather on the other. I will smear some silicone over the vent holes and plug the centre hole on the breather type cap I have in place. That will seal it up.
I didn't know it would have an effect on things.
Old Aug 26, 2016 | 07:33 AM
I run no pcv. If you are going for stock what old cutlass said is fine. Many guys plug the oil filler tube with a freeze plug. Very common. But many guys also run breathers on em. . Just depends what your taste and use is.
Old Aug 26, 2016 | 07:41 AM
76olds's Avatar
Hookers under Hood
I will plug it up. It sounds like the I have too much ventilation haha. My taste is chrome, but the chrome oil fill caps don't do it for me. I'll silicone the Edelbrock breather up, won't see the silicone anyway.
Cheers
Old Aug 27, 2016 | 06:42 PM
jpc647's Avatar
Cheers
Not sure you can have too much ventilation. These old motors do have a lot of "blowby".
Old Aug 29, 2016 | 03:01 PM
BlackGold's Avatar
Oh, I don't know. I've seen a few crankcases which have been ventilated by throwing a rod through the side. I'd call that too much.
Old Aug 29, 2016 | 03:13 PM
If you have too many openings you lose the positive ventilation. The PCV draws a vacuum so you can pull air through the vent on the opposite side of the engine.
Old Aug 30, 2016 | 04:49 AM
jpc647's Avatar
Haha, well yeah, that is true. In super extreme circumstances, lol .
Old Sep 8, 2016 | 05:58 PM
76olds's Avatar
Hookers under Hood
Put-er-ther guys!! Thanks for the advice. I smeared some silicone on the vent holes under that breather, also in the centre hole. So I'd say ther is not ventilation getting in through my oil fill pipe now.
I also put the ground wire back on from the fire wall to the block that I took off a couple years ago lol, thanks Oldcutlass for the advice on that one too!!.
Cheers
Eric
oldsmoboogie
Aug 25, 2016 07:18 PM
Gooner
Aug 1, 2014 04:04 AM
Snowdog
Apr 11, 2009 11:43 AM
ct1979
Oct 13, 2008 10:44 AM
iuhoops83
Aug 2, 2007 11:22 AM
