wingbat engine help
Old Jun 7, 2017 | 08:07 PM
wingbat's Avatar
wingbat engine help
Does anybody know if the 69 Olds Cutlass Coupe engine will bolt up to my 66 Cutlass Convt.? If it will not bolt up, what modifications do I have to do?
Old Jun 7, 2017 | 08:12 PM
tru-blue 442's Avatar
Old School Olds
Welcome. Replacing a 330 with a 350? Bolt n go.
Old Jun 7, 2017 | 08:25 PM
svnt442's Avatar
What trans are you running and what was behind the donor engine?
Old Jun 8, 2017 | 10:08 AM
Of course, this is only important if the new engine came from an AT car and is going into an MT car. Otherwise it's not an issue. One thing to be aware of is that 1964-67 Olds motors used a different crank flange bolt pattern than did the 68-90 motors. Use the flywheel/flexplate that matches the year of the engine. The other thing is to use the water pump/pulleys/accessory brackets as a matched set. You really want to transfer these parts as a matched set from the old motor to the new one.
wingbat
Jun 8, 2017 08:00 AM
nolabigdawg
Nov 16, 2014 06:45 PM
805cut
May 3, 2012 08:11 PM
MJAKS462
Apr 15, 2010 02:34 PM
Olds luvr
Mar 17, 2010 06:57 PM
