What Year Motor?
Old Sep 5, 2019 | 01:55 PM
Bugs's Avatar
Question What Year Motor?
Hello folks. I am new to the forum and have a question (of course I do) for you all!
I have a 1929 Ford sedan hot rod. It has an Olds engine and a GM350 trans. I was told it is a 70/71 Olds 350 5.7L motor.
From the below listed block and casting numbers, can anyone tell me exactly what this motor is? Year, HP, what it came out of?
Engine Block: 33M362984, 395558 2
Cylinder Heads: 411929, 8
Thanx
Old Sep 5, 2019 | 02:26 PM
78Cutlass4Speed's Avatar
Looks like you have a 1973 vintage 350. The casting number 395558 was used for 350s until 1977(?). The number 8 heads (411929) were used 1973-76. The partial VIN stamping 33M362984 is the key. The first 3 is for Olds division, the second 3 is for 1973, the M is Lansing, MI, and the last six digits are the last numbers of the cars VIN. If the trans is from the same car, the 362984 will be stamped on the transmission as well.
Old Sep 5, 2019 | 04:09 PM
1976, actually. 1977 was the first year for windowed main webs in all Olds gasoline engine blocks, so casting numbers changed.
Old Sep 5, 2019 | 05:24 PM
8.5:1 compression ratio
180 hp @ 3800 RPM
275 ft-lbs @ 2400 RPM
Some sources say 200 hp and 300 ft-lbs with dual exhaust.
Old Sep 6, 2019 | 05:36 AM
Bugs's Avatar
Thanx for the info.
The spark plugs are Delco R45S.
It has a 4 barrel carb.
It has dual exhaust.
Old Sep 6, 2019 | 03:25 PM
cutlassefi's Avatar
Originally Posted by Bugs
Thanx for the info.
It has a 4 barrel carb. It has dual exhaust.
Lots of stuff you can do with that. First would be to put early 350 heads on it. From there there are lots of aftermarket pieces available. Kinda cool, an old Ford with an Olds powerplant, neat.
Old Sep 7, 2019 | 07:35 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Early heads with a cleanup mill and .027" or .028" head gaskets will give 9 to 1 vs 7.9 to 1 stock. I did the same with a stock 76 350. 62 to 64cc #6 heads, .028" Rocket Racing head gaskets, bought the last pair they had for right around 9 to 1 with the 14cc stock pistons. 025" to .030" in the hole. I also did a custom 214/214 cam from Cutlassefi. You need stall with it, especially if it has highway gears but a 70 Cutlass is way heavier, so it may not be required. It probably needs the nylon timing set changed anyways, do a mild cam swap at the same time, stock cam is less than 200 duration. Also buy or make an EGR block off plate. A big EGR valve uglies up an otherwise beautiful SBO. Agreed cool car with a unique power plant.
MyBlue72
Mar 5, 2018 10:33 AM
Zachary Riggs
May 2, 2017 05:17 AM
Marshtonk
May 11, 2015 10:19 AM
1981cutlass
Feb 19, 2014 09:41 PM
fiona72
Dec 31, 2010 12:50 PM
