What vacume advance springs should i use?
Old Mar 18, 2009 | 09:43 AM
PmL69's Avatar
I just bought a new accel distributor for my stock 69 350. i was wondering what springs i should use for the advance. the chart that came with it is
color curve start engine rpm total
gold 400 1600
silver 600 2800
black 600 4000
The gold springs are in the distributor now. I would greatful for any help!!
PML
Old Mar 18, 2009 | 12:01 PM
rocketraider's Avatar
Oldsdruid
I'd lean toward two silver or one silver and one black, which would probably be pretty close to having it all in by 3600. The two gold combination brings it all in by 1600 RPM which is just a little quick for an Olds engine. Your ideal street engine setup is all mechanical advance in by a few hundred RPM above start of your cam's RPM range. Yah, I know that'll start an argument, but it has always worked well for me.
You can experiment with different combinations to get the curve you want. You can measure it with an advance timing light or ideally with a Sun or Marquette distributor machine if you can find one, and someone who knows how to use it.
Not sure about Accel, but I used to put Crane adjustable vacuum advance cans on my stuff and found that their published spring combinations for a desired advance curve were dead accurate.
Old Mar 22, 2009 | 06:47 AM
PmL69's Avatar
Thanks man!! i took your advice & used the silver & black springs. Its ALOT better now!!
This site rocks
PML
rcdynamic88
Aug 7, 2014 11:28 AM
WTony
Jun 29, 2013 05:11 AM
pcard
Feb 11, 2013 05:09 PM
1acesmith
Aug 11, 2011 11:03 AM
71cutlasssx
Dec 2, 2009 06:13 AM
