What price could i get from a Ok 307?
Have a guy that is intrested in my old 307, stock, and with 5A heads, dont know how many miles, the engine dont use Oil or water, just swetting a little from intake gasket,and rear seal probably, no problem with the engine at all.. the timingchain feels tight in nice, follow with exhaust manifolds and Cross over pipe,, somethines its poff in the carb, could it be that the camshaft is bad on some of the valve? Sounds like the lifter slips on the cam.
Engine without carb and waterpump..
Any Ideas?
Any Ideas?
I agree that this wouldn't be worth too much here, but in Norway it might have a higher value. Here, you'd look for and find or build whatever motor you want. There, it could mean the difference between some Olds guy having his car on the road or not. It may not be worth $500, but I would also err on the side of not junking it if it runs.
Ok thanks, i yeah i will not just throw it away either, it could be ok to have an extra engine too, if some terrible should happend with the new engine i will use soon. I can always make some storage space for it if so.
Is it right that the 5A heads are the best sbo heads?
It have stock Iron intake too.
When im looking at the marked here i have only see some few other 307 and not bigger engine..so looks like the market is a little low at the time.
Keep it unless someone is willing to pay a good amount for it. As said 307's aren't worth much here. The 5A heads are the best 307 heads and aren't crack prone like 3A heads. Of the 77 and up heads, they are the best but that doesn't say much.
Dead Reckon
January 18th, 2015 07:31 AM
ss0my69
February 20th, 2014 02:43 PM
