What has happened to these pistons?? 215 V8
Old November 22nd, 2011, 06:34 PM
russell-t's Avatar
I am going through my first ever engine teardown project. MY 215 V8 was
making loud valve train noises,and decided a cam change was in order.
Removed the heads to get them checked at a machine shop,and saw
this strange looking damage. Cleaned carbon from #7 and saw the pock
marks on the piston in the 1st picture. The other 2 pictures are of pistons
#3,and #5 before cleaning them. All of the pistons are showing some type
of pockmark damage,but none as extreme as #7. What has happened here
that would cause this type of damage?
russell-t is offline
Old November 22nd, 2011, 06:49 PM
Rickman48's Avatar
I would say that motor sat for a few years, and the rust got at it!
What I'd be more concerned with are the marks around the edge of the pistons!
The pics look like they hit the head - and they distorted the top of the piston!!
I hope you're taking it all the way down, as there's more amiss than valve noise!!
Rickman48 is offline
Old November 22nd, 2011, 06:57 PM
svnt442's Avatar
I agree that it looks like rust, but would they really use cast iron pistons in an aluminum engine?
svnt442 is offline
Old November 22nd, 2011, 07:15 PM
Did this engine have a head gasket go on it? Pitting like that I've only seen on rusted items. Even my 455 I tore apart this summer didn't have damage like that on the pistons, although it had a ton of rust in the block. That damage almost looks like the piston was starting to disintigrate. That's why I asked bout the head gasket leak or overheat?
BTW, what does the other bank of pistons look like? Same or good?
Allan R is offline
Old November 23rd, 2011, 06:54 AM
The rust was like said above from an engine that probably sat at some point in its life. I too am concerned about the marks on the outer face of the pistons.
oldcutlass is offline
Old November 25th, 2011, 04:31 PM
russell-t's Avatar
Would water sitting in the cylinder for a long period of time make this kind of pitting
in an aluminum piston?
The engine did have head gaskets on it and was running a week before teardown.
The other bank of pistons does not look as bad,but they still have minor pitting on the
surfaces. I'm taking it to a machine shop to check everything out,and will get some
new pistons in it.
Old November 27th, 2011, 12:40 PM
64Rocket's Avatar
I'm leaning towards detonation. Like this is the high compression engine and regular gas was used. under small loads it was just enough to detonate a little and create hot spots. If it was water siting for period of time the cyl wall would have considerable amount of rust. It does look somewhat like water, it would have sat sometime to pit the piston like that, and rusty cyl walls would be very noticeable. So my thought detonation from today's bad gas or regular gas when hi test is needed. Or both bad gas and small amount of water in the gas.
How long has the car been driven, or has it sat for long periods of time between driving?
Gene
64Rocket is offline
Old November 28th, 2011, 08:49 AM
russell-t's Avatar
To Gene: I bought the car in April 11 from the 3rd owner who said he bought it in
2003. He put approx. 9000 mi. on it during that time. Papers he gave me showed an
engine rebuild at 43,000 mi. No specifics on what was done. Told me the car sat for
long periods between being driven. The car had carb problems that would not allow it
to stay running. Replaced the spark plugs with new Champion plugs from parts store.
Comparing old plugs to the new ones, the electrode on the new ones are longer,
meaning they burn hotter. Timing was set to 10btc.
Your post makes sense to me, as the cylinder walls had no rust damage to them.
Bad gas in the tank, carb not adjusted right, too hot plugs, too much advance, valve
train noise and whatever problems that may cause; makes me think that the pistons
were the victim of ALL these issues combined with a little water. And abuse.
Would lean carb settings would work to cause detonation? Ran engine for long
periods of time after carb rebuild (10 to 15 minutes) then test drove at highway
speeds. Hoping this history can show those who know about this stuff what they
need to tell what has happened here.
Old November 28th, 2011, 09:55 AM
allyolds68's Avatar
Have you ever used ether (starting fluid)? I've seen similar pitting on diesel pistons from ether use
allyolds68 is offline
Old November 28th, 2011, 04:24 PM
64Rocket's Avatar
From what you say, it all sounds about right. What does the heads look like? Can't tell by the pic's. if there any marks to show over size pistons. To me it looks like all the did was a re-ring job. Just rings, rod brgs and mains.
I would just whiz-wheel the block and pistons. Blow all the dirt from the top of the piston down to the first ring. Pull a couple of lifters and see what they look like. Replace cam and lifters if there is any cupping of the lifter. Everyone I every worked on had bad lifters. Check for broken valve springs and replace valve stem seals. Finish it up and down the road.
Now if you feel you need to do the whole engine, "Kanter" and "Egge" are maybe the only ones with pistons. They should have everything else or maybe local parts can get some parts. Good luck.
Gene
64Rocket is offline
Old November 29th, 2011, 07:58 PM
russell-t's Avatar
to allyolds68:
I never used starting fluid on this engine, but it's possible the previous owner did
seeing he was having problems starting it due to carb problems.
To Gene:
Have taken the engine to the machine shop,and now will be suffering high anxiety
till I hear what the TOTAL amount of cash will be. After seeing this damage I've
decided to have everything checked out. Pay me now, or pay me later.
Many thanks to all of you who have replied to my post. Helped me come to a
decision on what to do.
Russell-t
Old November 29th, 2011, 10:26 PM
Rickman48's Avatar
I know that motor wasn't the 'peppiest', back in the day - had a '62 Special wagon as a DD for a while.
Maybe someone tried some 'NITRO' in it!!
Old January 18th, 2012, 07:56 AM
russell-t's Avatar
At this moment the block and heads have been gone through by the shop
and an explanation of what happened has been revealed to me.
The pockmarked pistons are a result of antifreeze from a head gasket leak
or other problem sitting in the cylinder for a long time before the 1st rebuild.
When breaking down the bottom they discovered thread marks on the crank
from careless removal of the pistons to hone the cylinders and change the
rings. The block and heads are now back together and I'm now waiting for
them to break it in.
Old January 18th, 2012, 02:02 PM
Originally Posted by russell-t
The pockmarked pistons are a result of antifreeze from a head gasket leak or other problem sitting in the cylinder for a long time before the 1st rebuild.
So I was right.
Allan R is offline
Old January 19th, 2012, 07:27 AM
'87 Delta 88 Royale
rustyroger's Avatar
I've seen a lot of similar damage on Rover v8 engines, essentially the same engine.
Nearly always caused by not keeping the antifreeze up to strength leading to electrolytic erosion, the first symptom normally being a blown head gasket.
I'd have the block and heads very carefully checked for this before you start paying machining bills.
Roger.
rustyroger is offline
Old May 14th, 2012, 09:15 AM
russell-t's Avatar
I've had the entire engine rebuilt by a reputable machine shop in my
hometown.They replaced all the pistons and bearings,redid valves and
valve seals,camshaft,timing chain and gears,and oil pump. Tested it on
an engine run-in stand before giving it back to me. It's back in the car
and I'm now sorting thru all things involved to get it to run right.
Thanks to all of you for your input on this post.
Russell-t
Erinyes
August 12th, 2014 05:06 PM
1970cs
May 4th, 2014 05:05 AM
help442onguam
October 12th, 2011 08:15 PM
oldsdroptop
June 2nd, 2009 07:03 PM
Starfire61
March 24th, 2008 06:01 AM
Quick Reply: What has happened to these pistons?? 215 V8
