What can I expect 1974 rocket with #6 heads
I will be planning out the build on my Oldsmobile 350 it had the stock #8 heads, I purchased a set of #6 heads that I will be cleaning up for the motor, my cam and lifter kit will be a comp hydr. Roller, the cam is 0.505 lift, I have not chose rockers but they will be roller or roller tip, pistons will be 0.030 it will have a solid spark system which I have not chosen, and high volume pumps, topped off with Edelbrock 750 cfm and a performer intake, headers of course. What sort of hp and torque can I expect also what should my crank gear timing be, zero, advanced or retarted? Also, my rear end is a 3.08 posi.
Also, going from the #8 heads to #6 heads, what would the difference in hp and torque be on its own theoretically?
Will you be installing larger valves?
I wouldn't use the regular Performer, I'd use the RPM. I'd also put a bit more lift in it as well as the full roller rockers vs the roller tip. You may also want to think about changing the gear to a 3.42 or similar.
Just the head swap alone should be worth about 20-25hp. Total resulting hp should be in the mid to upper 300's depending on cam and head work.
Hope this helps.
Hope this helps.
Also on the roller tip rockers...not worth it. The pivot ***** DO gall rocker pivot if you don't have enough ZDDP in the oil...at least that's the way it's been in a '77 350 with #4 heads as well as a Ford 302 and 351 with the same rockers. They might work with a stock cam, but anything over .490 valve lift and an upgraded spring (don't remember the pressure), in my experience, has galled at the pivot point with conventional oil.
Hope this helps.
Hope this helps.
I don't think there is any difference in the heads depending if you are having porting done, it just depends on what compression you are trying achieve as to which set of heads will make it come out right, there are multiple piston designs to choose from. You have to do all the math before starting.
From a great source 442.com
6 '70 350 64cc 403859 W-31's had larger 2.000 intakes. '69
W-31's?
8 '73 - '76 350 79cc 411929 Smog heads. Have huge bb-sized 79cc
chambers yielding poor compression
ratios without extremes of compensation.
W-31's?
Pretty sure this man ^^^^^ has never steered anyone wrong regarding Olds stuff. You're paying for the valve job anyway, 8 2.072 intake valves plus the job will be menial compared to the cost of the entire build and worth every penny in the end.
I picked up a set of #6 heads with 2"/1.625" valves, port work, filled crossovers and milled to 55cc. With the Magnum 280 cam with 14cc pistons, it went 12.70's in the quarter, according to the previous owner.
Put in good valves. Don't waste money on stock style replacements. Use a swirl polished intake and exhaust valve such as those offered by Milodon. Approximately $200 for all 16. Have the head of the exhaust valve turned to 1.625. While not the cheapest way to go its not the most expensive and the valves are very high grade.
Since you have been reading way to much propaganda just do what you want. I was just saying for a good street engine that can use todays gas with no problems. #8's work fine with a set of flat tops 0 decked and a thin head gasket and they have larger exhaust valves than other heads, if you port them they work fine.
I have a bare block right now, those pistons will not be returning, and they were nice and black. I am certain on forged for my new ones, and believe I am going with a flat top, I'm not building a racer but the flat forged will sure be enough.
Surprised to hear the huge jump in hp as stated by cutlassefi.
Personally I swapped #5 for #8. I have not driven it yet but put a lot of miles on the #5 heads. I don't trust the exhaust valve seats on those old heads. Though #5s having soft seats is supposedly propaganda according to some on this board! I am interested to see how to motor feels compared to when it had #5s.
The problem with using earlier 330-350 heads on mild street builds is there are no over the counter forged pistons ( that I'm aware of ) that would provide you with an ideal CR ( say around low 9's ). This is why the big chambered #8 heads are actually a good thing. AFAIK, the #8's will flow just as good as the earlier heads if you port the exhaust sides.
So in summary, if you want to use your #6 heads, then you need a dished piston to keep your CR from being too high.
If you're going to use flat top pistons then the #6 heads will make your CR higher than I think you want. If you used flat tops with #8 heads then your CR would be right about where you're going to want it to be at.
The #8 heads just need an hour or two with the grinder just under the valve, a lip blocking the bowl. The actual bowl is better than a J, 3A, 4A or 5A exhaust port. Expect 10.25 to 10.5 to 1 with #6 heads.
That is the calculator I used, but I used the wrong stroke, where would I find that? Also, I'm new to a lot of this, what is everyone's opinion on the compression ratio around 10.25-10.5
I got 10.62:1 with relief pistons...Obviously a little high.. Very high, so if I have to use forged flats I should use the #8 heads. But for a strip-like motor I would want something like the #6 heads.
#31
I'm going to be building a similar motor so I've plugged the numbers in few times for myself. A lot of unknown info on your motor, but I still get 9.5 to 1 on an estimate. You should be close. I would take a minimal amount of material off the block deck to square it up and resurface the the heads if they need it and use a .040 thou thick gasket. Should keep the compression more reasonable. I used a 5.8cc dish piston, 68cc head, .015 deck clearance for my calculation. With a flat top you should be a little over 10 to 1.
#32
For an example on the difference in power in the rating methods, my '71 Owners manual shows the 350-4bbl engine rated as 260 hp GROSS and 200 hp NET (71 was the transition year between the GROSS and NET so they published both). Same engine but 60 hp difference just from the rating method.
#33
#34
Like I mentioned before, post the numbers you're punching into the calculator.
You can get 'streetable' compression and use your #6 heads. You just need a piston with a small dish. Problem is, there aren't any available. The reason why the #8 heads are being suggested is because they work great with easily available forged flat tops.
#35
I am no expert, but I think your performance will either be the same or a little better if there are a lot of miles on those, the buildup over time will cause restrictions especially in airflow and of course general wear will hurt them. But I think if it was looked at with restored sets of heads, you would see the large difference in compression and power
From all the info I have read there is really not much difference in any of the Olds SB heads other than chamber sizes so use what makes things come out right and do some port and runner work.
#36
A knowledgeable porter would only need a couple of hours to improve the number 8 heads. Directly under the valve, just removing the ridge in the bowl has to be huge gains. Just get them to add the 2" or 2.072" intake and remove the bowl ridge with a bowl hog. The #8 heads already have the right size exhaust valve. The factory just horribly restricted the opening below the valve, after that, it is a decent port. Two days with a valve job, porting and guide work would be about right.
#37
Well the person selling me the heads decided to back out of the deal, I really didn't want to do a lot of porting work or have a lot done i just don't have the time or the money for a good job. I think while I Finnish my car I will look out for an improvement, and hopefully some big block heads, I understand that I can make the 8s better but there are better heads out there, I would really like to play with a set of big block heads
#40
Well honestly this is the only place I have heard good things about them. Because I am taking the time to build the motor I have no problem waiting to find a 6,7 or big block head, I like the larger valves and same or better flow and a good CC with compensation. I think just about every engine builder I have read comments from has said what sorts or heads and tricks to use, not one has wanted to be near the 8s, also it's just cool that you can put any head almost on it.
