water pump removal
Old Jul 29, 2014 | 06:56 PM
blkbety1977's Avatar
water pump removal
I have removed everything except the work itself. There is an aluminum extender holding the pulley on the pump. I can't remove it? Can't remove pump without first removing extender then pulley.
Old Jul 29, 2014 | 07:33 PM
Are you talking about the spacer between the pump and the fan? Once the 4 bolts are removed just give it a little tap on the side with a hammer. It has pilot hole in the center that the pump shaft centers in.
Old Jul 29, 2014 | 10:21 PM
As noted, the aluminum spacer has a tight fit on the water pump shaft. Couple this with galvanic corrosion due to dissimilar metals (aluminum and steel), and you get a stuck spacer. Gentle "persuasion" will loosen it.
at3reg98
Aug 13, 2013 10:16 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
72Ctlss
Jun 23, 2009 03:12 PM
SMOKEYMTNKUSTOMS
Jun 21, 2006 04:42 AM
SMOKEYMTNKUSTOMS
Feb 21, 2006 11:16 AM
