valve lash 350 rocket
Old Dec 13, 2019 | 09:27 AM
billi1989's Avatar
hi guys
how to adjust valve lash for 350 rocket 1979 engine?
please guide me
tanX
Old Dec 13, 2019 | 09:32 AM
Oldsmaniac's Avatar
The Olds 350 has no adjustment for valve lash. The lifters are hydraulic and lash is zero.
Old Dec 13, 2019 | 09:43 AM
Although there is no adjustment the preload built in should be around .040-.050
Old Dec 13, 2019 | 06:49 PM
This is assuming you are using the factory style rocker arms and bridges.
Old Dec 13, 2019 | 11:00 PM
coppercutlass's Avatar
Chevy budget Olds powered
Valve lash or preload ? 2 very different scenarios.
Old Dec 14, 2019 | 02:12 AM
svnt442's Avatar
With factory rockers and bridges, with both lifters on the base circle of the cam, torque the bolts to 25 ft/lbs.
If you are using aftermarket adjustable valve train, again with the lifters on the base circle of the cam, tighten the nut (you should have screw in studs and posi locks) until the pushrod starts to drag (zero lash) and then go ½ turn further with the nut and lock it in place.
Old Dec 14, 2019 | 08:43 PM
Toro X6's Avatar
Hi Billi - I know you said "rocket' 350, but in 1977 GM started to mix and match engines between divisions.
Many an Olds left Lansing (and presumably other plants) with Chevy 350s under the hood.
This applies in 1979 also.
Please be sure you really have an Olds engine in your car. You can determine this by a particular character in the VIN, or by looking at the engine, if you know what to look for. Or check this out: https://www.teambuick.com/reference/...eng_visual.php
Chevy does have adjustable rocker arms from the factory, but not Oldsmobile.
If you do have an olds engine and it is 'ticking' from the rocker area, you likely have a worn rocker arm/bridge that should be replaced.
z11375ss
Jul 11, 2023 11:02 AM
gmarquez
Oct 7, 2015 04:49 PM
BlueBeast
Aug 20, 2015 07:28 AM
jeffsfleet
Apr 8, 2013 12:14 PM
Olds442redberet
Jan 27, 2013 04:07 PM
