Vacuum Leak or Normal noise?
I just installed an Edelbrock 1406 in my '71 Cutlass using a stock 4bbl intake and an Edelbrock air cleaner.
Car seems to run just fine, but I hear an air-sucking noise while driving - particularly under acceleration in 1st gear. The noise seems to disipate through 2nd and 3rd, unless I'm pushing the throttle a bit (like going uphill for instance). In nuetral, there's no funny noise when I goose the throttle.
I'm thinking the car would run lousy if I had a serious vacuum leak, right? Or should I be looking for a leak? How come I only hear this weird air noise when I'm driving - and not when I rev the engine in nuetral?
This is my first "open" air cleaner. So, is the noise I'm hearing normal, as it's drawing in a lot more air than my old 2 bbl air cleaner would?
Anyone else experienced noticing this noise when you switched to an open air cleaner?
Gee, not sure. Have you tried putting a stock air cleaner on and running it to see if the noise is still there? I don't have an open air cleaner on my car but I'd guess that it would make more noise without the metal baffling.
Yeah... I don't have another air cleaner to try - as the 2bbl won't fit. I was thinking of cutting some aluminum stock to encircle the filter - sort of create a closed air cleaner just to see what would happen. But I'm thinking that might starve the carb of air.
Maybe I'll give it a try - nothing to lose. The noise just bugs me because it sounds like something is "wrong"!
I've got a 1406 on my car, and I can't say I notice an "air sucking noise" Do you have a spacer on top of the carb that the air cleaner rests on? Does it sit flush? If not, maybe the air cleaner is not sitting right.
Can you hear the noise if you rev the motor in park? If so, about if you take the air cleaner off. Does the sound get worse? If not, maybe take a short drive down the block with the air cleaner off, see if it gets worse or louder.
66ninetyeightls
Ninety-Eight
22
August 23rd, 2010 05:40 PM
nukesec1
August 9th, 2009 02:08 PM
