torque converter?
Old Apr 2, 2009 | 02:38 PM
  #41
88 coupe's Avatar
Junior Member
........ Norm -how is it you're the only one that doesn't get this?
Which part is it, that you think I do not "get"?
Norm
Old Apr 3, 2009 | 05:32 AM
  #42
cutlassefi's Avatar
TC
I don't know, you tell me. Spin it anyway you like Norm, whatever makes you happy. I'm done here.
Jim, again keep us posted on the outcome.
Old Apr 9, 2009 | 03:15 AM
  #43
65cutty's Avatar
I was able to order the 60801 lunuti vodoo cam thru jegs, though its not a stocked item ant more, again thanks to all very good learning experence....jim
Old Apr 9, 2009 | 06:42 AM
  #44
cutlassefi's Avatar
TC
Very good. Should work well for you. Don't forget to degree it no matter what. Shouldn't need much of an increased stall converter if any with that cam either.
Again, glad we could help.
Mark
Old Apr 19, 2009 | 07:56 AM
  #45
65cutty's Avatar
will my 600 cfm be ok with this set up...jim
Old May 5, 2009 | 11:09 AM
  #46
65cutty's Avatar
got the heads back from the machine shop but have a question, had the heads plained 20,00 thousands and are using mondelo's thin steel head gaskets do you think I'll be ok with the intake or will it have to be cut down also?....jim
Old May 6, 2009 | 02:04 PM
  #47
Warhead's Avatar
NO.
BTW, "milled" 20 thous will be represented as .020".
Jim
Old May 7, 2009 | 03:28 AM
  #48
65cutty's Avatar
OK, its hell getting and forgetting most everything, will the intake need milled also?
Old May 7, 2009 | 11:12 AM
  #49
tonycpe's Avatar
I would think you should be ok with only milling .020 off the heads. but of course you will only find out when you mount it.
On my motor the heads were milled .030 the manifold bolted on but i was close to needing the manifold milled at the front and rear rails , which may or may not want to push out the rubber seal.
I wonder if there has ever been a thread on to use or not to use the factory rubber end seals.
Old May 7, 2009 | 04:26 PM
  #50
Warhead's Avatar
Originally Posted by Warhead
NO.
Jim
Let me re-iterate.
You should be fine.
At most, you may have to use silicone at the manifold ends, instead of the rubber end seals, if there has been no other cutting done. Mock up the intake if you have any doubts.
YOU SHOULD BE OK.
JIM
Stevec
Apr 20, 2012 05:46 AM
scrappie
Apr 3, 2008 06:41 PM
Fred H
Jan 24, 2008 07:58 PM
SPEEDROCKET
Dec 18, 2007 06:35 PM
Surfrat67
May 14, 2006 03:42 PM
