Timing cover
Old Mar 17, 2014 | 08:47 PM
jason's Avatar
Timing cover
I asked earlier about coolant in the oil. As I was repairing a timing cover leak I did notice corrosion at the top of the cover at the coolant ports. I thought I sealed it well there. Could coolant be getting in the oil there? Would I be best to just replace the cover. Engine has not really been ran very long, never overheated. Earlier post was oil, coolant problems. Thanks for the help. This is sons first car we are building together hoping to get on the road soon.
Old Mar 18, 2014 | 01:27 AM
nsnarsk65cutlass's Avatar
Yes it can, also intake and a cracked block.If any doubt about the cover i'd replace it.Nick
Old Mar 18, 2014 | 07:53 AM
When I have the timing cover off, if there's corrosion I usually hit it with a 7" disk sander to flatten out the pitting before reassembling. If it's badly pitted, you'll have a difficult time getting a good seal.
Old Mar 18, 2014 | 08:12 AM
jason's Avatar
Well it looks like a new timing cover. Any thoughts where to get one? And hope there is no intake or head problem.
Old Mar 18, 2014 | 09:18 AM
Octania's Avatar
What did you seal the cover/ block/ WP with?
Proper sealant such as Form-a-Gasket #2 would fill all such pits and seal.
I have seen rust pits so bad at the impeller area that it may leak thru there.
Of course, a new plate is the best solution.
Be prepared to test fit and modify to fit right, as a NEW new part may be made in China.
$80 - dirt cheap:
http://www.ebay.com/itm/64-79-OLDSMO...2771e9&vxp=mtr
Might as well put a new timing set in there, eh?
http://www.ebay.com/itm/OLDSMOBILE-4...3D360875902740
Old Mar 18, 2014 | 09:32 AM
jason's Avatar
I used black rtv and a new gasket. Has a new timing set. So thinking new plate, gasket and use the form a gasket #2.
Old Mar 18, 2014 | 04:09 PM
jason's Avatar
Well I got the timing cover off. It has pitting around the coolant ports and some small grooves. drained engine oil it was thinner than normal. Looked kinda whitish tan color. Removed a drain plug on each side of the block to drain coolant. Hoping either a good reseal of the cover or should it be replaced? Any thoughts of it being intake or heads. It did not smoke at all and ran fine.
Old Mar 18, 2014 | 09:19 PM
Lars's Avatar
a new valley pan is about 16 bucks at rock auto. as long as you are there. and draw the line there! no maw's
Old Mar 18, 2014 | 09:38 PM
jason's Avatar
That is the second time some one mentioned MAW'S. What is that?
Old Mar 18, 2014 | 10:29 PM
Magna86's Avatar
MAW=Might As Well........Coolant leak become engine rebuild etc. Just replace the cover to save yourself grief.
Old Mar 19, 2014 | 02:47 AM
MAW get one of Rob's new, SUPER Anti-MAW helmets, just to be sure:
Old Mar 19, 2014 | 02:49 AM
Nop's Avatar
Nop
2-stroke 1-cylinder guy
Stay clear of this, too:
jpc647
Jun 10, 2013 11:48 AM
Hairy Olds
Oct 27, 2011 05:35 AM
442scotty
May 13, 2009 05:42 PM
sklbndt
Apr 15, 2009 04:34 PM
csouth
Jan 21, 2009 09:35 AM
