Timing chain "pisser" / oiler
Old Mar 20, 2013 | 10:21 AM
boese1978's Avatar
Where can I get new / replacement oilers ( can I just use any plug for the non-olier one?), the one that threads into the block behind the timing chain ( what is the actual name? came up with zero at AZ and OR) I tried finding info using the above to no luck here...68 Olds 350...thanks
Old Mar 20, 2013 | 11:11 AM
ihengineer76's Avatar
Both plugs are a hex socket pipe plug, and the oiler has a .040" hole drilled in it IIRC. One of the other members may recall better.
Old Mar 20, 2013 | 12:28 PM
TripDeuces's Avatar
The front plugs are not pipe plugs, those are straight cut threads. The rears are 3/8 pipe plugs.
You can just drill a .040 hole.
Many Olds specific vendors sell the front and rear plugs. Fusick, Mondello, Parts Place, etc.
Old Mar 20, 2013 | 12:39 PM
Run to Rund's Avatar
The two plugs have different thread sizes, and yes they are straight thread. I grind the chamfer off the socket I use so I can grab the full depth of the hex, since it is so shallow. The smaller one on the passenger side has the spit hole.
Old Mar 20, 2013 | 03:09 PM
I guess I was suffering from a little CRS today...
Old Mar 20, 2013 | 04:02 PM
My442's Avatar
I have some NOS ones.
Old Mar 21, 2013 | 03:53 AM
boese1978's Avatar
What are you askingfor them?
Old Mar 21, 2013 | 03:55 AM
boese1978's Avatar
I may be blind but I can not find these suckers on the sites mentioned, link anyone? What exactly are they called?
Old Mar 21, 2013 | 01:41 PM
boese1978's Avatar
anyone?????
Old Mar 21, 2013 | 02:00 PM
TripDeuces's Avatar
http://www.mondellotwister.com/OilingSystem.htm
Inline Tube:
Part Number - INL10823 1964-72 Oldsmobile Engine Oil Passage Plugs All V8 Engines 4pc Set $16.00
You're right, couldn't find it on Fusick or The Parts Place but here are some options. A lot cheaper from Inline Tube
Old Mar 21, 2013 | 04:03 PM
boese1978's Avatar
Thanks, just what I was looking for.
Troys Toy 70
Jan 23, 2013 05:36 AM
svnt442
Sep 10, 2010 10:21 PM
442scotty
May 13, 2009 05:42 PM
olds87
May 24, 2006 08:30 PM
