Timing chain
Old Jun 19, 2015 | 04:44 PM
truckerlary's Avatar
Timing chain
I am in the process of putting my 350 olds engine together. I ordered a double row timing chain (Comp Cams 2113) from Summit Racing and when I went to install it today the chain is way too long. When installed on the top cam sprocket the chain hangs below the crank sprocket. What am I missing here or did they send me the wrong kit.
Old Jun 19, 2015 | 05:25 PM
Sounds like you were sent the wrong parts.
Old Jun 19, 2015 | 06:30 PM
+1. Check the numbers on all the boxes against the numbers listed on the JEGs and Summit web sites.
Old Jun 19, 2015 | 06:42 PM
I just called summit and they are going to send me a new set. I checked the numbers on the gears and they are 2213 A & B while the number on the box says 2113. Not sure what this set is supposed to fit.
Old Jun 19, 2015 | 07:10 PM
Hmmmmmm...
I think you're on to something.
Old Jun 20, 2015 | 09:41 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Honestly buy a Cloyes Street roller set. I have heard a sorts of issues with the other sets especially accuracy once a degree wheel is put on. Cloyes according to many sources are accurate within a degree.
Old Jun 21, 2015 | 03:39 AM
coppercutlass's Avatar
Chevy budget Olds powered
I have degreed a cam with. Comp cams timing chain and found it to be right on the money . Also according the bil trovato the pro gear timing chain units which is what I have now have the cam pin bores in the wrong place. When I degreed my cam it was right on . The pro gear timing chains are nice I bought mine through rocket racing.
Old Jun 21, 2015 | 05:35 PM
Ed Carpenter's Avatar
Just had the same problem. Will need to send back, but hated I will have to wait 3 days for the replacement.
http
Apr 26, 2013 09:58 AM
442scotty
May 13, 2009 05:42 PM
dccutlass
Sep 17, 2007 03:08 PM
Mr. King
Mar 25, 2007 12:33 PM
olds87
May 24, 2006 08:30 PM
