Timing a 76 cutlass
Old August 30th, 2018, 09:49 AM
Frankied37's Avatar
Timing a 76 cutlass
Alright guys so first off I have a 76 cutlass that was used as a drag car out in Arizona, from what I’m told it’s a 350 bored 30 over with a t6 transmission which I’ve never heard off and an elderbrock carb and a Msd distributor. Long story short my grandfather bought the car and it had been sitting for a few years and I bought it from him.
I changed the oil and topped off all the fluids, set the timing to 16degrees and took it for a ride and it doesn’t like to shift out of third it feels like and didint like to start right away when it was hot. I do have a leak in the o ring on the spodometer cable on the transmission but the dip stick still showed fluid when I checked it.
My question is what would cause the car not to shift if the fluid is full and smells fine and second what should the timing look like? The engine did have s 150lb tank of boost on it that I took off, did the difference of the throttle body plate do anything to the carburetor?
thanks
Frankied37 is offline
Old August 30th, 2018, 10:17 AM
Did you check the fluid level with the engine warmed, running, and in park?
oldcutlass is online now
Old August 30th, 2018, 10:20 AM
Frankied37's Avatar
Yes and it was reading on the dip stick a little low.
Old August 30th, 2018, 10:30 AM
Does the pump whine or trans make any peculiar noises? Is the fluid a nice bright red and does not have a burnt smell? Are the 2 modulator rubber hoses good and is there vacuum at the modulator with the engine running?
Your timing is probably fine for now.
Old August 30th, 2018, 10:38 AM
Frankied37's Avatar
The fluid doesn’t smell burnt and is a pinkish color, I’ve been using dex2, as far as a I know there’s no modulator for vacuum and the 2 lines coming from the radiator to the transmission looks good. Thanks
Frankied37's Avatar
And sorry the pump doesn’t whine and overall nothing sounds out of the ordinary.
Old August 30th, 2018, 11:00 AM
I missed the T6 part, not sure what that is.
Old August 30th, 2018, 11:03 AM
Frankied37's Avatar
I’m going to have the car on a lift this weekend and as far as the t6, that’s what my grandfather told me but he also said that the carb was a carter and when you open the hood you see the big elderbrock sticker on the carb lol I’m not 100% sure it’s a t6 or if that is a real thing or not
Old August 30th, 2018, 11:10 AM
First, I ASSUME we're talking about a MANUAL trans? There's no such thing as a "t6" transmission. There is a T56 six speed, which is used in newer cars. It requires some work (including floorpan mods) to adapt to an Oldsmobile.
In 1976, you could get a T50 five speed trans from the factory in these cars. That transmission is the only five speed that's weaker than a T5. It was only available behind the V6 and the pavement-ripping 260 motors. If that T50 is what's behind an Olds 350, I'm not surprised that is isn't working properly.
How about you start by figuring out exactly what transmission you have and posting a photo of it. Guessing won't provide you any useful answers.
joe_padavano is offline
Old August 30th, 2018, 11:51 AM
Frankied37's Avatar
Transmission is an auto and I know the pan is rectangular, I’ll take a picture of it Sunday.
Old August 30th, 2018, 12:49 PM
Maybe this may help:
Old August 30th, 2018, 12:52 PM
If it's an OD trans, $10 says it's a 700R4.
Old August 30th, 2018, 12:56 PM
Frankied37's Avatar
Huge help!! Does look like the 700r4 I’ll get a better look Sunday. Thanks a lot!
Old August 30th, 2018, 12:58 PM
If it's a 700R4, there will be an aftermarket adapter plate between the engine and trans.
Old August 30th, 2018, 01:00 PM
Frankied37's Avatar
That will be easy to spot since it’s missing the fly cover
Old September 1st, 2018, 06:08 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
If it I the 700R4, the TV cable must be set properly and have the proper geometry for the cable. Make sure the proper TV cable bracket is on the car. There should be slight tension at idle and full cable pull at full throttle.
olds 307 and 403 is offline
Old September 3rd, 2018, 06:25 AM
Frankied37's Avatar
I have the car in the air now, pan bolts were loose and replaced the oring in the Spedo cable, don’t think it’s a 700r4. Looks like a 200
Old September 3rd, 2018, 06:29 AM
Yeah, we suggested the 700R4 because you said this.
Obviously the pan is not rectangular. That's a 200-4R.
Old September 3rd, 2018, 07:01 AM
Frankied37's Avatar
Thanks Joe, guess I don’t have to tell you now that this is my first Oldsmobile. My fault won’t do that again. Still trying to figure this thing out the cable going up the back of the engine looks intact nothing seems out of place. Fluid smells fine and is a good color, car shifts from park to d and r fine but won’t shift out of 2nd.
Old September 3rd, 2018, 07:05 AM
A 200-4R in stock form won't live very long in drag strip use. Unless you know that the trans was modified for HD use, it likely needs to come out. The Buick Turbo community has developed fixes for every weak link in the 200-4R, but it isn't cheap to incorporate them.
Old September 3rd, 2018, 07:11 AM
Frankied37's Avatar
It ran fine before it was parked.
Old September 3rd, 2018, 10:45 AM
Frankied37's Avatar
Update, the throttle linkage was moved and never opened up all the way to open up the kick down cable for the transmission to shift. Everything works fine now just have to mess with the idle and timing a bit. Thanks for everyone’s time
Chips56
December 15th, 2018 07:39 AM
76Olds88
November 7th, 2014 04:20 AM
Big Todd
May 30th, 2011 12:17 PM
young olds
April 17th, 2011 07:59 AM
jkoester122
December 10th, 2010 01:46 PM
Quick Reply: Timing a 76 cutlass
