thoughts on my sbo?
Old Nov 30, 2013 | 06:17 PM
805Cutlass's Avatar
thoughts on my sbo?
hey guys i just pulled my 350 out of my 72cs. This is my first time doing a rebuild of any kind, but thanks to this site ive learned alot. Im in the process of taking things apart and checking the overall condition. So it looks like i have a 72 block but my heads are different. one is a 7 and the other is a 7a? it might sound stupid but does this mean the motor has been rebuilt? my goal is to up the compression but still be able to run pump gas. A daily driver but still fast enough to smoke those ricer hondas ....here are some pics of what im looking at, im open to thoughts and suggestions
Old Nov 30, 2013 | 06:26 PM
billmerbach's Avatar
major noob
Well I can see you have the high comp pistons would I be correct in saying he has close to 300 HP or would the heads he has change this
Old Nov 30, 2013 | 06:29 PM
805Cutlass's Avatar
this motor was ruuning i had it in the cutlass it seemed peppy of the line but no ***** mid or top end....are you saying these are not the original pistons that came with the 72's?
Old Nov 30, 2013 | 06:32 PM
major noob
No they are my 70 block has them I'm also doing a rebuild also plus I get my knowledge from these men on here still learning so if I'm not sure I'll tell you but I'm pretty darn sure these are the originals
Old Nov 30, 2013 | 06:46 PM
coppercutlass's Avatar
Chevy budget Olds powered
Bill those are the low comps bud. 23 cc's no god can't do much with em .
Old Nov 30, 2013 | 06:48 PM
major noob
Well I feel stupid those look like mine and some others I've seen and was told high comps how can you tell the difference
Old Nov 30, 2013 | 06:49 PM
The size of the dish and deptn is what gives it away.
Old Nov 30, 2013 | 06:51 PM
major noob
Just figured that out lol sorry 805Cutlass I screwed up
805Cutlass's Avatar
bummer! the dish on them didnt look real deep but then again this is my first time doing this.
Old Nov 30, 2013 | 06:53 PM
It's big. It's hard to get any compression with em to run a decent cam to make power.
major noob
I see that now I just looked at mine and I can see the difference between my high comps and his low comps thanks copper for clarifying that for me
Old Nov 30, 2013 | 06:55 PM
805Cutlass's Avatar
no worries bill we're all learning. so as far as my heads go one 7 and the other 7a.. is this normal to see what exactly does this mean? where these two heads different sizes?
Old Nov 30, 2013 | 06:56 PM
They are very close in. Design if any diffrences .
Old Nov 30, 2013 | 06:59 PM
major noob
All I know is # 6 heads are desirable I guess they have better flow
Old Nov 30, 2013 | 07:02 PM
805Cutlass's Avatar
i just ran into this kit on summit wondering if this would work with my block. it claims to be Approximate compression ratio 9.64:1 with a 70cc head.... or would it be better/ cheaper to buy a set of speedpro flattops and rebuild kit.
http://www.summitracing.com/parts/fe...-000/overview/
Old Nov 30, 2013 | 07:06 PM
Bill the flow numbers are almost the same between 6 7 and 7 A if I remember right. The 5's are the best in stock form .
Old Nov 30, 2013 | 07:15 PM
major noob
Well I gotta get some 5 heads then I'm just gonna shut up then
Old Nov 30, 2013 | 09:31 PM
Lars's Avatar
them bores look deep, whats the # on the timing shelf
Old Nov 30, 2013 | 09:37 PM
The other thing I noticed is one of those pistons looks like it almost has no dish ? maybe the way the pic was taken but even on the other pics at the bottom of the bore you can see a dish.
Old Nov 30, 2013 | 10:17 PM
805Cutlass's Avatar
sorry lars dont really know what you mean. whats the timing shelf?
Old Nov 30, 2013 | 10:20 PM
805Cutlass's Avatar
i think its the way the picture looks coppercutlass....all the pistons looks like theyre the same size just the right side of the block has alot more crud then the left
Old Dec 1, 2013 | 05:29 AM
tru-blue 442's Avatar
Old School Olds
The #'s Lars speaks of
are right under the front of the
intake manifold. There is a shelf
for the timing chain gearset, right
behind the waterpump. the by-pass
hose from the thermostat housing goes
right over the top of those #'s.
They will tell which block you have.
Old Dec 1, 2013 | 07:39 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The Speed Pro pistons will put you around that if your heads CC around 70 and you leave the pistons around .025" in the hole with a .041" gasket. Take your block and heads to the machine shop, see what needs done. I would get the heads CCed for sure. That kit is fine for the street and expect to use pump Premium when done. I believe the only difference on those heads is spring pocket depth and the 7A's have induction hardened exhaust seats. I have never heard of Olds heads wearing out exhaust seats.
Old Dec 1, 2013 | 08:01 AM
ransomolds's Avatar
looks like a great project!the best advice i can give is to invest in mondello's technical reference manual.it will help you in all steps of your project.it will explain the number locations for your block and heads and charts to look them up.
f-85
Aug 15, 2010 11:15 AM
shaks 442 clone
Oct 18, 2008 09:41 AM
Fishcity
Jan 23, 2008 11:41 AM
GoldOlds
Jul 24, 2007 07:30 PM
bobem12
Jun 18, 2007 03:17 AM
