switching to 350 heads on a 403
Old Feb 25, 2017 | 10:37 PM
geeves's Avatar
I have a set of 7a heads from a 350 Olds that I would like to have machined to fit my 403. What I need are the bolt hole size and locator pin size that need to be drilled. My engine is back together and I would like to drive it while I gather the needed parts for the upgrade. I want to take these in to the shop but i don't have a 403 head to send with them for the measurements. Any help would be appreciated. Thanks.
Old Feb 25, 2017 | 11:08 PM
svnt442's Avatar
They have to be drilled for ½" bolts. As far as the size of the locator, that I don't know.
Old Feb 26, 2017 | 10:03 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
As said 1/2" bolts so slightly oversize so bolts don't bind. The dowels, one on each head, needs enlarged to 5/16", I believe. If they are going to the machine shop, 2.07"/1.625" valves with the bowls opened up and a clean up mill are a good idea. Also any worn guides replaced, new seals and upgraded springs.
Old Feb 26, 2017 | 08:46 PM
geeves's Avatar
Thanks for your replies. I never thought to measure this stuff while the 4a heads were off, but like I said, I would like to drive the car this summer while getting the parts ready for the modification.
Old Mar 1, 2017 | 06:12 AM
brownbomber77's Avatar
17/32 is the drill bit but any competent machinist can figure it out. Things I have discovered on my stock 403 build. The pistons are .030 in the hole. Consider about a 70cc combustion chamber and a standard fel pro gasket at .040 crushed thickness and you're only looking at 8.5:1. I just got .011 MLS head gaskets from Smitty. That will give you 9.0:1.
Old Mar 2, 2017 | 06:11 PM
Kennybill's Avatar
MLS, multi layer steel? Who made the gaskets you got from Smitty?
Old Mar 3, 2017 | 08:19 AM
No idea. There's no identifier on there or anything. There is a chance he went right to the gasket maker and had them custom made. I can't find that thin of gasket anywhere.
Old Mar 3, 2017 | 08:31 AM
I believe Smitty did exactly that, mentioned it on here. I just bought the 330-455 .028" gaskets from Rocket Racing, very nice for the price. I wish they had composite 403 gaskets in the .028" thickness.
Old Mar 3, 2017 | 10:01 AM
svnt442's Avatar
http://www.cometic.com/i-24769372-ol...tegory:1280258
Old Mar 3, 2017 | 08:09 PM
I should have said for less than $100 each.
Old Mar 3, 2017 | 08:51 PM
svnt442's Avatar
Well....lol.
Old Mar 4, 2017 | 06:10 AM
Smitty's are $110 plus shipping. AND they're reusable.
Old Aug 8, 2017 | 08:43 AM
78 omega 468's Avatar
110 each or is that a pair, wishful thinking.
Old Aug 8, 2017 | 06:03 PM
That should be a pair, Contact Smitty, use Paypal.
Old Aug 9, 2017 | 12:02 PM
Mrgadget's Avatar
403 rebuild
What dish amount do those pistons have or are the flat top?
Thanks, Frank
Old Aug 9, 2017 | 09:51 PM
Factory 403 pistons have 21CC dish.
Old Aug 10, 2017 | 07:44 AM
Mrgadget's Avatar
Thanks for that info.
Frank
Old Aug 11, 2017 | 08:10 PM
Yeah...they're not small... 7.9:1 Compression back in '79
Old Aug 13, 2017 | 09:16 AM
Mrgadget's Avatar
Good to know since my '70 is supercharged, I would want it to be about 8:0 to 8:2, it is now 8:12.
Old Aug 20, 2017 | 12:06 PM
Seff's Avatar
For what it's worth, .011 gasket and .030 in the hole will set you up for a .041 squish distance, which very close to the optimal 0.040 squish.
88hurstolds
Jan 20, 2020 11:39 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
DarkStar
Oct 21, 2009 07:35 AM
shopaholic07
Aug 4, 2009 08:19 AM
442scotty
Sep 16, 2008 04:54 PM
