Stock compression on 1970 350 4bbl?
Old June 30th, 2010, 03:09 AM
oldzy's Avatar
Just wondering what the stock compression is on 1970 350 4bbl.
I want to eventually rebuild my 1972 CS 350 4bbl closer to 70 specs. Changing pistons all that is really needed? Does the 70 use similar type dish style pistons?
I would like a little more power w/o going overboard, and still be able to use the A/C, have a slightly bigger than stock cam, etc.
oldzy is offline
Old June 30th, 2010, 04:50 AM
10.25:1, the dish on the '72's are deeper. You could get a mild cam that closely matches the original specs. or go slightly more aggressive with the modern grinds, and easily run a/c with no issues
1969w3155 is offline
Old June 30th, 2010, 04:51 AM
507OLDS's Avatar
The 70 engines used a piston with less dish,compared to 72,so that is where the compression difference is.The CC's of the heads are the same.You could reuse the 70 pistons into your 72 350,as long as the pistons are good,& your cylinders don't need bored.If they do need bored,you can get aftermarket high-compression pistons.
507OLDS is offline
Old June 30th, 2010, 09:53 AM
oldzy's Avatar
I would prob get aftermarket pistons. Are the flat top 2320 Speedpros the ones I would want to get close to the 1970 specs? I don't want to have to add a big cam, or drastically change the torque converter/rear end gears either for example. I will be adding a 3.42 posi eventually.
I royally screwed up my last rebuild... HMV-272-2 Crane Cam, stock deep dish pistons, RPM intake, stock 2.73 gears... I had to put the pedal halfway down before the car would move. Like a really bad clutch or something.
oldzy is offline
oldzy
December 12th, 2011 06:26 PM
oldzy
April 11th, 2011 05:36 AM
charlie_hustle
November 24th, 2010 06:08 PM
oldzy
August 10th, 2010 04:49 AM
cts-v
January 10th, 2009 04:55 PM
Quick Reply: Stock compression on 1970 350 4bbl?
